LSD swap plz help
Old Feb 26, 2009 | 12:41 AM
zero310's Avatar
fc
LSD swap plz help
so i have a 87 4 lug rx7 that i am tryin to swap out for a tII lsd but when i go to line it up the two rear mounts fit but the one that bolts to the subframe the two studs off the diff dont wanna line up wit the slots any suggestions?
Old Feb 26, 2009 | 09:42 AM
EPD's Avatar
EPD
BFH.
it should be a straight swap, the chassis are the same. You may need to go straight up instead of an angle.
You will need turbo axles and a different drive shaft if the rest of your drive train is NA
Old Feb 26, 2009 | 09:54 AM
87 t-66's Avatar
not a drifter
yep, should be a straight swap.
gabescanlon
Sep 15, 2015 06:57 AM
Rotospectre
Sep 13, 2015 11:22 PM
