87 TII Tech Questions
Old May 23, 2002 | 05:52 PM
Scracho's Avatar
Okay guys I finally found an `87 TII and I've got a couple of questions about the car.
1) How do I check for bad compression? (Indications, or Simple Tests)
2) Can I fix my Wiper Intermittant switch without going broke? (Re-Soldering)
3) Throttle peddle feels hard. (Possible dry cable?)
4) Leaking gas tank (Bladder Problems) Wreckers or New?
5) How do I check to see if it's been rebuilt?
This is all I can think of right now. The car runs exceptionally well, but I would like to just double check things myself before I have Mazda tell me different!
Old May 23, 2002 | 07:38 PM
Icemark's Avatar
1: get a compression test done.
2: yes you only need a relay
http://2ndgenrx7.freeservers.com/cgi...%20switch.html
3: possibly or bent and damaged linkage, or bad cruise control servo
4: replace ASAP, if you go used make sure there is no rust inside.
5: you can try running the VIN and matching the engine number to the body.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
