convert carb to fuel?
Old Feb 24, 2009 | 05:32 PM
tane's Avatar
s3v3n
GA convert carb to fuel?
ive got a 85 fb carb that i want to convert to fuel injected...im not fully familiar with these cars so i dont know what all ill have to do...can anybody whos done this before help me out?!
Old Feb 24, 2009 | 10:56 PM
hanman's Avatar
Dude, that's going to be a chore, why do you want to do that?
Old Feb 24, 2009 | 11:12 PM
Crit's Avatar
No distributor? No thanks
The GSL-SE trim level of the 84-85 cars was fuel injected. If you can get a harness, ECU, block, and a few other things, you can upgrade to the stock Fuel Injection setup.
Old Feb 25, 2009 | 07:38 AM
hanman's Avatar
Exactly, what you are talking about here is a complete engine swap with the necessary electronics, or trying to cobble together a FI system for your current block. Which means a custom manifold with injector bungs and a fuel management system.
Old Feb 25, 2009 | 08:56 AM
Aaron Cake's Avatar
Engine, Not Motor
It really depends on how he wants to go about it. If I was doing this, I would just make an adapter that allowed me to mount a throttle body on the Mazda lower intake manifold, then add injector bungs and run the thing with a Megasquirt. Going with the stock EFI from the GSL-SE is kind of crazy.
Old Feb 25, 2009 | 06:46 PM
tane's Avatar
s3v3n
well i heard that fuel injected may be better...no?
Old Feb 26, 2009 | 03:56 AM
trochoid's Avatar
Old Fart Young at Heart
Better is a relative term. Carbed rotaries, older ones, have been shown to produce more peak hp generally, along with less fuel mileage. It can run upwards to 2k+ to do the full conversion, depending on intake and ecu/fuel systems installed. The following link may give you a general idea of what Aaron suggested.
https://www.rx7club.com/1st-generation-specific-1979-1985-18/progress-my-car-pics-d-695200/
Rotospectre
Mar 28, 2018 03:33 PM
Jun 26, 2016 10:21 AM
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
