Omp
Old Feb 24, 2009 | 05:31 PM
SecondGenPat's Avatar
In search of turbo...
Exclamation Omp
Hello. I have this idea in my head for a "different" mechanical omp setup,
I need to know how much oil pressure is fed to the opm from the oil galleries in the engine/ front cover.
If you were to remove the OMP, this would be the pressure at the the front cover, here
I tried searching and reading the FSM but no luck.
Thanks in advance
-Pat
Old Feb 24, 2009 | 07:25 PM
HAILERS's Avatar
HAILERS
The hole on the right is the feed hole. That oil comes off the input shaft.
It fills a cavity in the pump and then the oil dumps directly back into the hole on the left which leads to the pan.
The OMP is a Pump. It takes that oil that fills it's cavity, and pressurizes it and sends the oil up the OMP lines.
Ain't much of any pressure in that cavity imho.
Old Feb 24, 2009 | 09:32 PM
Ah, OK.
Thanks for the info.
-Pat
Andrew7dg
Aug 6, 2017 01:41 PM
lnlreaper
Sep 27, 2015 09:59 AM
