Blue smoke at redline shifts...but never any other time?
Old Feb 24, 2009 | 01:46 PM
jjwalker's Avatar
MECP Certified Installer
I did my research on this is and my reasearch would indicate it is a bad oil seal, BUT things don't all add up.
If I shift at 6500 no smok at all. Never smokes at idle hot or cold. Never smokes at any time with the exception of 7300rpm + shifting. Above 7300rpm, it puffs a small blue cloud.
It is always either a small cloud of blue smoke or absolutely nothing at all. It's a head scratcher.
My car also doesn't consume abnormal amounts of oil. It only consumes maybe a quater of a quart if not less every 1000 miles and I have to drive it hard to do that. My thought is that the oil seal leaks slightly only at extremely high rpm, but never at any other time. Weird.
Any ideas?
Old Feb 24, 2009 | 02:20 PM
eage8's Avatar
1308ccs of awesome
S4 or S5?
NA or turbo?
are you premixing?
Old Feb 24, 2009 | 03:05 PM
jjwalker's Avatar
It is a 1990 Vert, stock NA motor. I put a slight amount of premix in (about 2 ounces and filled up).
Old Feb 25, 2009 | 12:51 AM
jjwalker's Avatar
Nothing eh?
Old Feb 25, 2009 | 12:54 AM
cmanns's Avatar
Smoke moar
Extra oil injectors kick in somewhere around 5500 rpm or so starts to really show around 7k rpm
If you just rev it quickly do you see smoke? If you rev it around 6k and pop it over 7.5k a few times (holding it around 6k) do you see plumes?
It's exactly what I've always had, no smoke otherwise I could be wrong that it's the oil injectors but I'm pretty sure.
It's nice taking it all the way to 8k rpm and leaving a trail of blue smoke at the ******* behind you hehe
Hope that helps m8
Old Feb 25, 2009 | 02:51 AM
RotaryEvolution's Avatar
Sharp Claws
bad oil seals, as they progressively get worse it will smoke at lower and lower RPMs.
try thicker oil, 20w-50 for now to get by.
Old Feb 25, 2009 | 05:49 AM
cmanns's Avatar
Smoke moar
seriously? I was told it was other injectors kicking in for the high rpms O.O
Old Feb 25, 2009 | 08:40 AM
jjwalker's Avatar
Ouch, that sucks.
I know my way around a reciprocating engine in and out, but a whole lot about rotaries. Is the same scenario as a piston engine, meaning it could probably last a while and just slowly get progressively worse? That is of course beside a catastrophic seal failure happening.
Old Feb 25, 2009 | 08:48 AM
VAXHeadroom's Avatar
commit(rnd()&sense-acts)
I agree with this advice. My 88 N/A 'vert has this issue and it has progressed down from 6500 to 5500 (187K miles). I've tried MANY different oil viscosities and for me 10W30 produces the least smoke. YMMV Go with what works, live with it for now (it won't hurt anything in the engine) and save your nickles for a rebuild. The progression from 6500 down to 5500 happened across about 25,000 miles (I was driving it 100 miles a day), so my experience was that this degeneration happens kind of slowly. I now have a blown coolant seal, but the opinion is that these are not related except for the fact that I've got 187K miles on the original motor.
I also found that it only happens 1) when shifting (the quicker I shift, the less smoke I get), and when holding the engine RPM at or above the 'oil smoke point', i.e. if I hold it at 5000, no smoke. If I hold it at 5,500, I'm James Bond...which I've used once or twice on the road when being tailgated by some idiot
Good Luck!
Old Feb 25, 2009 | 09:05 AM
jjwalker's Avatar
Well, I was thinking of doing 20w50 but all I can find is rotella. Is that okay?
Old Feb 25, 2009 | 09:15 AM
jjwalker's Avatar
okay. And if I don't get smoke then what?
I'll try that after my "no BAC" cold startup test we are doing in another thread.
Old Feb 25, 2009 | 01:31 PM
jjwalker's Avatar
Alright, I had to go run some errands and I gave the car some hell and voila, no smoke. Now I am even more dumbfounded.
I am out to go do the 3500 RPM test right now.
Old Feb 25, 2009 | 02:07 PM
EmbassyBlack's Avatar
im having the same type of problem.
in neutral or while driving if i rev it over 6500 rpm i get a cloud of blueish white smoke that comes out. when i first got my car and didnt know much about it a guy that supposedly know alot about rotaries told me to use synthetic and thats when it started. i went back to mineral oil and it still does that. btw i dont have cats so maybe thats a possible cause too
Old Feb 25, 2009 | 02:35 PM
the motor came out of a car that had around 25k on it. Once i got the motor in i did a full tune up except for wires, that was April-May
btw OP lol sry to hijack your thread
Old Feb 25, 2009 | 02:38 PM
the car that the motor came out of had around 25000kms on it, i did a full tune up except for ignition wires once i got the motor in which was around April-May.
btw OP lol sorry to hijack your thread
Old Feb 25, 2009 | 02:40 PM
st1llet0's Avatar
That happens to be as well, I've always thought it was the fuel injectors cutting way back when you let off the throttle, however the engine is still spinning, and creating a lot of vacuum, which I thought kept sucking oil from the oil injectors, and burning it all up. Does anyone with a blocked off omp running premix get these symptoms?
Old Feb 25, 2009 | 03:14 PM
jjwalker's Avatar
Nope, 3500rpm test for 30 seconds yields nothing.
Old Feb 25, 2009 | 05:18 PM
Sharp Claws
wierd, i haven't seen results from a lighter weight oil reducing smoke but anything is possible, generally i always start out with lighter weight oil and move up from there. what happens is the oil control o-rings get squared off and brittle and can no longer hold oil pressure. at higher engine RPMs the oil seal carriers float around to the point that the oil can get past the seals, i suspect a lighter weight oil might be able to be wiped off before it can get past the side seals but it really is situational so different oils may yield different results. i haven't seen oil injectors cause excessive smoking before so i just doubt that is the cause.
if the oil seal o-rings begin to crack from age then the smoking will get progressively worse much quicker. my GXL smokes from startup until fully warmed up now due to cracked oil seals. cracked oil seal o-rings expand with heat and smoke when cold but seal up when warm, squared off brittle o-rings smoke at high RPMs and eventually get worse over time, both have similar results but at opposite ends of the RPM range.
Old Feb 25, 2009 | 09:16 PM
GatorFC's Avatar
carbon footprint
My car has done the same thing for as long as ive had it. When I shift above 6K or so RPM's I get one or two backfires and a small cloud of bluegrey smoke and a strong burnt oil smell. If i try this a second or third time, it makes little or no smoke at all. The car also does not have cats so this could be why.
A similar thing would happen when I would start it. It used to spew tons of smoke whenever i started it and it would rev up to 3K rpm cold cycle but It has gotten better since.
Old Feb 26, 2009 | 01:51 PM
jjwalker's Avatar
I think there was a puddle of seafoam still in my manifold because I did some extremely hard driving yesterday and no smoke, not even at redline.
Old Feb 27, 2009 | 11:28 AM
jjwalker's Avatar
I warmed it up and tried again this morning, still no smoke. I have 2 possible explanations...
1) Puddle of seafoam in the manifold froma week ago. It could have got stuck behind the VDI valve and decided the enter the motor when I floored it several days later.
2) Oil control ring got stuck temporarily.
I am betting on the first one though, it makes more sense.
Old Feb 27, 2009 | 11:34 AM
cmanns's Avatar
Smoke moar
<snip>
awww that sucks, mine sends out a plume @ high rpms guess it's not good I rev past 8k
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
pzr2
Aug 15, 2015 08:29 PM
