turbo in n/a
Old Feb 21, 2009 | 05:15 PM
smithgrind's Avatar
turbo in n/a
wats the damage that u can do if a turbo is placed in a n'a rx7.
and can it be safely done
Old Feb 21, 2009 | 11:09 PM
diabolical1's Avatar
if you're asking about turbocharging a non-turbo Rx-7, then yes you can. damage can be a total blow up if you don't tune it right or use common sense when choosing a turbo and functional boost levels.
Old Feb 22, 2009 | 12:56 AM
RotaryRocket88's Avatar
Top Down, Boost Up
See the FAQ at the top of this forum.
https://www.rx7club.com/showthread.p...55#post5131155
Old Feb 22, 2009 | 02:02 AM
ncfc3s's Avatar
Spend the $5000 to buy a mint low mile turbo car.....Or one thats already been completed by someone else
Old Feb 22, 2009 | 10:36 AM
Aaron Cake's Avatar
Engine, Not Motor
Can I swap a Turbo engine/Jspec engine/13BT/etc into my Non Turbo?
Yes, check these links:
https://www.rx7club.com/forum/showth...threadid=26647
http://www.rotaryresurrection.com/ro...conversion.htm
What Turbo kits can I add onto my non turbo RX-7?
There are no longer kits formally made at the time of this post, however there are companies from time to time that do make available non turbo to Turbo Kits. Because most of these companies stop building the kits, or go out of business in short time, it is impossible to keep active links for them.
Most people that turbo a non turbo make their own kits:
Using the stock TII turbo, exhaust manifold with spacer, NA intakes and NA ECU:
http://www.aaroncake.net/rx-7/naturbo.htm
https://www.rx7club.com/forum/showth...threadid=88540
https://www.rx7club.com/forum/showth...threadid=88758
https://www.rx7club.com/forum/showth...hreadid=124232
http://users2.ev1.net/~ccoutts/turbo..._a_project.htm
Using the stock TII turbo, exhaust manifold, intakes, ECU:
http://forum.teamfc3s.org/showthread.php?t=37694
Turbo-NA Forum:
http://www.aaroncake.net/forum/forum...urbocharged+NA
Old Feb 23, 2009 | 01:24 PM
ncfc3s's Avatar
^lots of info that helped me in swapping out my n/a. Save yourself the aches and missed time in the car by buying a turbo car.
hotshot2014
Jul 18, 2017 02:30 PM
immanuel__7
Canadian Forum
Sep 2, 2015 08:26 AM
rxmiles
Aug 24, 2015 02:07 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
