brakes
Old Feb 19, 2009 | 07:41 PM
ICEY?'s Avatar
brakes
just got new brake rotors and calipers.. let this one machanic do it.. not my bakes have lost all pressure after 2 days... i have to push the pedel all the way to the floor to get it to stop.
what could this be?
i can take it back to the guy but he wont be back in tow till monday and i need my car now its my DD
THANKS!
Old Feb 19, 2009 | 07:44 PM
ITSWILL's Avatar
Wiring Nightmare
do you have brake fluid? my guess is that something is leaking.
Old Feb 19, 2009 | 07:53 PM
ICEY?'s Avatar
yes i do. its more then half way full...
Old Feb 19, 2009 | 08:06 PM
Napsterfreak15's Avatar
To rule out whether or not its leaking, add brake fluid, pump the pedal, and see if it leaks by looking on the ground and in your engine bay.
Have your tried pumping the brakes quickly to see if that would re pressurize your system?
Old Feb 19, 2009 | 08:16 PM
ICEY?'s Avatar
yes i have pumped re peatedly with motor off and on...
havent seen any leaks from under the ar...
Old Feb 19, 2009 | 08:21 PM
ITSWILL's Avatar
Wiring Nightmare
well if its not losing fluid, it could have some air in the lines, or the mechanic may have just F'd up your brakes and put them on wrong or something.
Did the mechanic by chance refer to the bolts on the brakes as "nubby things" lol
Old Feb 19, 2009 | 08:50 PM
fc3s91's Avatar
R.I.P Mark( Icemark )
You may also have a bad brake master. Did he bleed the brake from the right rear to left front? This will insure that all the air is out of the system.
Thanks Robert
Old Feb 19, 2009 | 09:05 PM
ICEY?'s Avatar
im pretty sure e did everything right... he has one it on all of my other cars before with no problems... i hope i dont have to pay more money to fix stuff lol...
Old Feb 19, 2009 | 09:15 PM
Hecubus84's Avatar
Informed Appreciation
I'd hazard a guess that you need to bench bleed your master.
Try these threads:
https://www.rx7club.com/showthread.p...Bench+Bleeding
Old Feb 19, 2009 | 09:47 PM
91 rx7's Avatar
speed maniac
did your mechanic spin the brakes pistons like make them tight by rotating them to the right( the rear ones ). it might be it. and how about the E-brake is it tight or loos?
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
