corrosion in engine how bad is bad?
Old Feb 19, 2009 | 08:09 AM
hanman's Avatar
I am looking at buying a recently rebuilt engine from one of the members here. When he pulled the engine he said that he found corrosion at the BAC valve, when he pulled the coolant line off that goes to the block, he found a significant amount of corrosion.
Now, I am in a position that I have to make a decision whether or not to cancel the deal, or go ahead with it and hope for the best.
Any thoughts about the future of this engine if I go forward with it? He is selling the engine cheap, $500 so it is worth some risk. But, I don't want to go to all of the hassle of putting the engine in and having overheating issues or failure within a short period of time.
Just looking for opinions.
Thanks.
Old Feb 19, 2009 | 08:19 AM
pfsantos's Avatar
(blank)
If this is a short block, you'll be able to look into some cooling passages. You also want to know if it was rebuilt due to overheating, and whether housings were checked for warpage. I'm assuming the rebuilder checked the housing coolant seal grooves, but like I said, assuming.
Need pics. also.
Th0m4s
Feb 26, 2019 02:04 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
gtcd
30
Aug 19, 2015 02:44 AM
