dyno'd my 2nd gen.
Old Feb 12, 2009 | 09:52 PM
rx7vadim's Avatar
dyno'd my 2nd gen.
mods in sig.
149 whp, on 93 octane/no traling coil/bad rear brakes.
That night after dyno my rear right brake was locking up and smoking.
Should make 160 easy with traling coil and brakes fixed.
I also took afm cover off and it looked it was 100% open on wot.
Old Feb 12, 2009 | 09:55 PM
andresj's Avatar
bone stock
whats a lexan rear hatch?
Old Feb 12, 2009 | 10:25 PM
rx7vadim's Avatar
polycarbonate
rx7vadim's Avatar
window
Old Feb 13, 2009 | 01:12 AM
MaczPayne's Avatar
Mac Attack
Why 93 octane?
Old Feb 13, 2009 | 07:59 AM
glhs0867's Avatar
U.S. Army Recon 93-04
Originally Posted by MaczPayne
Why 93 octane?
It runs lean up top.
You got that 125 on... .yet?
Old Feb 13, 2009 | 04:12 PM
drewski86's Avatar
Slow
That's a horrible reason to run 93 octane if it's true.
Old Feb 14, 2009 | 10:12 AM
arghx's Avatar
rotorhead
my timing was messed up on my old n/a car and it used to run lean up top all the time (like 14:1) and it never detonated. that was on 87. it put 172rwhp down
Old Feb 15, 2009 | 12:42 AM
rx7vadim's Avatar
it read 12.8 on dyno wideband.
93 to be on safe side, what if you fill up with old bad gas?
149 is nothing special, but on 2 plugs thats pretty good. when i fix my trailing coil, ill see if it adds %10 power like what people say.
Old Feb 15, 2009 | 01:07 AM
drewski86's Avatar
Slow
In a NA street car, you will probably never run into a situation where a bad tank of gas will be an issue. I don't remember where I read it, but the NA cars are rated for 84 octane (comes close with 87 octane + oil).
Did you do any sort of tuning? I didn't see it mentioned.
Old Feb 15, 2009 | 01:46 AM
rx7vadim's Avatar
just played with timing with a rusult of power loss.
i filled up with bad as once already.
oil = no more then 0.5 octance reduction.
Old Feb 16, 2009 | 04:11 AM
mwatson184's Avatar
holley guy
The 787B ran on 84 octane, I haven't read anything about it other than that though...
Old Feb 20, 2009 | 10:11 PM
WHY_TRY's Avatar
hmmm
Old Feb 20, 2009 | 10:15 PM
maac0953's Avatar
what TQ #'s did you get??
Rotate86
May 18, 2018 02:44 PM
