Haltech Installing IAC
Old Feb 11, 2009 | 09:36 AM
mzrx7man's Avatar
sideways!!
Installing IAC
Im gonna be installing a idle air control valve and when i was looking at the haltech wiring diagram i noticed there was 4 wires for that. I think the idle valve that people use that is on the uim (coolant line running on it) has two wires and haltech doesn't tell you which wires go to what. any ideas?
Old Feb 11, 2009 | 09:40 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
The 4 IDLE wires on the Haltech harness are specifically for 4 wire stepper motor valves, the OEM BAC valve on rotaries is a 2 wire deal, so you will need a PWM wire set to BAC to control it. No big mystery there. The other wise is power. This has been covered many a time.
Old Feb 11, 2009 | 09:52 AM
mzrx7man's Avatar
sideways!!
ok, now so i use the bac one and play with that and thats it huh
Old Feb 11, 2009 | 10:33 AM
AlexG13B's Avatar
brap brap brap
kinda, got mine in and it isnt the greatest, u gotta get the right settings on haltech and also i think on the actual bac itself (the screw)
did u wire up the bac yet?
Old Feb 11, 2009 | 10:46 AM
EFI Tech Wannabe
Yeah the OEM 2nd gen valve isnt that good, a 3rd gen valve would probably work better, but the best one to use would be the Haltech 4 wire valve. What ECU did you say you had, a K? the K's idle control would work best with the 4 wire haltech valve.
Old Feb 14, 2009 | 01:37 PM
Houstonderk's Avatar
My girl
I use the haltech valve and it seems slow to me, especially at the startup. It might just be my settings but everyone says to switch back to the stock bac.
Old Feb 14, 2009 | 01:50 PM
slo's Avatar
slo
registered user
Claudio, have you ever seen a stepper motor that controls a throttle cable?
It may be intended as a cruise control unit.
EDIT: look at this ford stepper motor http://img.okazje.info.pl/934/5292/th100/529277.jpg part number 95BF9F715AC, looks like it might bolt on in place of the stock FD bac.
Old Feb 14, 2009 | 09:43 PM
slo's Avatar
slo
registered user
ohps, link, meant to link to this http://www.compperformancegroupstore...ct_Code=307022
This adapts a GM stepper motor to ford TB, which have a BAC like the rx7, looks like it would bolt onto an FD.
24seven_dada
20
Nov 10, 2018 12:03 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Enzo1944
Sep 6, 2015 08:57 AM
