Can the ATF trick cause any bad Side effects???!!!!!
Old May 22, 2002 | 03:51 PM
M.C. Language's Avatar
i was driving my car, and it just doesnt seem to have the ***** it should anymore. So i thought im most likely loosing some compression. I would like to try the ATF trick, but am scared because i dont know if it can cause anything to go wrong!??
Thanks for the help!
-Ben
Old May 22, 2002 | 04:22 PM
ronarndt's Avatar
Ben- Instead of blindly assuming you have lost compression, why not spend a few $ and have a compression check done first to try to diagnose the problem. One of the things that pisses people off is mechanics just randomly replacing parts or performing "shotgun" service procedures to try to fix a problem. Whatever happened to diagnosing the problem and then doing only the work required? You will probably get people on this forum advising to do or not do the ATF fix, but why not find out what is wrong first. You asked for advice- my $.02.
Ron A.
Old May 22, 2002 | 04:24 PM
13BAce's Avatar
On a long vacation
I agree with Ron. It could be ALOT of things: Old spark plugs and /or wires, bad exhaust, etc.
CaptainKRM
14
Aug 26, 2015 09:52 PM
Wolf_
Aug 11, 2015 04:23 PM
