Aftermarket Downpipe.
Old May 22, 2002 | 01:01 PM
BoOsTin FD's Avatar
Powered by** Rotary
I ordered my downpipe today, and i was just wondering, when i install it, am i gonna smell fuel or something like that out of the exhaust? I'm just worried that it might stink a lot and i won't be able to sit in it. I have an aftermarket catback,stock main cat, and now i'll have downpipe.
Also how hard is it to install it ? Thanks
Old May 22, 2002 | 01:19 PM
Mahjik's Avatar
Mr. Links
Lightbulb
Nope, you won't have that "exhaust smell" until you replace the cat with a midpipe.
If you don't want that "exhaust smell" don't ever use a midpipe, hi-flo cats are fine.
Old May 22, 2002 | 01:27 PM
GsrSol's Avatar
Z06 powered FD
You shouldn't smell fuel unless you have a leak. I didn't do my dp because I had it installed at the same time the clutch went in. You might need new studs so be prepared.
From what I've heard it's best to soak the bolts with a lubticator when the car is hot, let it cool down and soak them again.
Old May 22, 2002 | 01:56 PM
ttpowerd's Avatar
HARRRRRRRRR
You will not get the fuel smell till you replace the mp as mahjik stated. It is not overly difficult to install depending on which brand you went with. Some don't match up well, or so I have heard. I got the m2 and it is supposedly the easiest to install.
Old May 22, 2002 | 05:48 PM
RecKleSs's Avatar
Adrenaline
The downpipe is one of the best mods you can do to your RX-7. Make sure to replace your old gaskets with the new gaskets. Don't worry about the fuel smell, because there will not be any.
renjiv2
57
Jan 25, 2024 03:34 AM
