airpump removal, pullys
Old May 22, 2002 | 05:49 AM
gzon's Avatar
I am going to remove my main cat and taking away the airpump, Can I use the STD pulleys? how long should the new belt be?
I have done a search and came up with nothing.
Old May 22, 2002 | 06:44 AM
dznutzuk's Avatar
Uncontrollable drifter
Don't be a Rikki-why don't you downsize your sign. it's ridiculous and quite useless-talk about not being a Rikki. Gzon, I suggest you buy a pulley kit-if you decide only to change the belt it will slip which is not good for your water pump, do you want a kit?
Old May 22, 2002 | 09:51 AM
gzon's Avatar
Will the belt slip at the waterpump? Will I have to get the bigger pulleys? Are you selling pulleys?
Old May 22, 2002 | 11:24 AM
rx7tturbo's Avatar
No, the belt will not slip at the waterpump.
Old May 22, 2002 | 11:38 AM
gzon's Avatar
Ok. anybode who knows the exact length to use with standard pulleys?
Old May 22, 2002 | 02:04 PM
Which Pulley Kit(s) are best?
Old May 22, 2002 | 02:17 PM
RAZZOR's Avatar
I tried 2 belts 5pk740&5pk700 goodyear or gates belts on a buddies r1 and it worked fine ,he knurled the waterpump pulley aswell.Cant remember wich one worked but its close.If you have a larger waterpump pulley 5pk780 works.
Steelwheelz
Sep 15, 2015 03:22 PM
Enzo1944
Sep 6, 2015 08:57 AM
