Help. No brakes
Old Feb 3, 2009 | 02:02 AM
bsidewayz's Avatar
Help. No brakes
Hi there,
I just got home from a spirited drive in my series 7 FD and whilst driving my brakes stiffened up and it was hard to stop. I pulled over to check the pads and from what I can see they looked fine.
The E-brake light has been on for a few weeks also. Could this be contributed to the problem?
Also, I noticed whilst driving home carefully. The engine idles pretty high and wierd.
Are these all symptoms of a new brake change? I apologise for the newbish question. Any help is much appreciated.
Andy
Old Feb 3, 2009 | 02:33 AM
JoeyMazda's Avatar
"81 RX-7
I'm not too familiar w/FD I'm a 1st gen. but I had the same problem and I had an air leak in the hose that goes connected in the converter.
Old Feb 3, 2009 | 02:50 AM
bsidewayz's Avatar
thanks for the reply. i just checked out the brake cylinder and the fluid is on the minimum line. ill probably got fill it up tomorow morning. i hope this fixes the problem. still doesnt really explain why the engine is idling rough and off tune.
Old Feb 3, 2009 | 08:26 AM
ptrhahn's Avatar
Sounds like something to do with a vacuum leak with the brake booster and/or the check valve in the booster line.
Old Feb 4, 2009 | 12:44 AM
bsidewayz's Avatar
yep everythings in check now. the e-brake light has disappeared after topping up with brake fluid.
one of the vacuum hoses had cracked. taped it up and the the brakes work properly.
chiefmg
Sep 10, 2015 07:46 AM
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
