water temps too low!!!
Old May 21, 2002 | 09:16 PM
My pfc is showing between 30 and 40 degrees when fully warmed up, in 90 degree weather. Could this be corrected (recalibrated) on ther pfc commander, or is it a bad sensor? The stock gauge in the instrument panel seems to be reading normal, which is about right smack in the center, as always. Anyway, this problem, isn't letting the 7 perform nearly as well as it should. I'm desperate for help!!!!! If, in fact it is a sensor, where would it be located.
Old May 21, 2002 | 10:01 PM
user 84205's Avatar
search...Im pretty sure this was discussed a few days ago.. Im not sure of the solution, but I know someone was asking..
Old May 21, 2002 | 10:19 PM
atihun's Avatar
It's most likely the thermosensor.
Old May 21, 2002 | 10:29 PM
Actually, i'm the guy that made that other thread a few days ago.It just died out. But, It's just frustrating the heck out of me. Especially, when I've almost solved this one. Believe me, I've put over 100k miles on this search engine in the past few days alone. Also, what's the differnce between the water temperature sender and the thermosensor, and where exactly are they located? Thanks in advance.
Old May 21, 2002 | 10:38 PM
user 84205's Avatar
my bad.... I PM'ed ya 93R1
Also i would like to know the difference too, I always though, the water temp is routed to the car computer first, if that is true, both temps should be the same correct? I thought like in older cars, your temp just goes straight to the gauge... im I wrong...?
Old May 21, 2002 | 10:58 PM
I think new cars go to the ecu first because it's electronic. The older ones used mechanical, so they had to go straight to the instument panel. Therefore, in this case it should go to the computer 1st.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
sherff
Sep 12, 2015 12:22 PM
dillrx7
Sep 7, 2015 09:38 AM
