Probfec B 2 help
Old Jan 22, 2009 | 04:17 PM
Probfec B 2 help
The car was set up to a wastegate pressure of .8, thing is the car has a Profect B2 fitted, with it turned on and set to LO setting. Whilst cycling through the options the warning boost is set to .8 bar which i presume is the wastegate pressure.
The High setting has a warning boost of 1.2bar and with the car mapped for .8 i would like to know if i should reduce the high setting to .8 to eliminate the risk of accidental over boost.
Furthermore, I would be really grateful if some one could advise on the parameters or whether simply turning off the profect B would be ok as its mapped to the wastegate spring pressure.
Finally, Is there a way of Checking the pre set boost level? I know how to adjust the boost but is there a button i can press that will bring up what the target boost is set too on High or Low without changing it?? Just to make sure what i'm seeing is the Pre set level? (Just a little confused and would like some clarification)
Thanks in Advance....
P.s. If it makes any diff, T04R,PFC,Profect B2,All fueling mods.
