any help or advice?
Old Jan 22, 2009 | 01:31 PM
greengoblin94FD's Avatar
WA any help or advice?
got 94 fd, my airpump is dead....its making that loud noise. my oil pessure at idle is 0-10, and raises to about 40 on highway. just got the oil changed, and i'm running10w-30 valvoline. when i took off the oil cap today, it looked like mayo under the cap. i'm guessing that my oil is contaminated. any advice or help would be much appreciated. Zach
Old Jan 22, 2009 | 03:15 PM
Upgrayedd's Avatar
Double Dose
What noise is your airpump making? If it's making the "moo" when as the engine is windibng down then it's normal. If it's more then that look at picking up another airpump used, in fact I may still have one in my bin of parts.
Don't trust the factory oil gauge 100% it's pretty typical for it to break on the FD. Mine doesn't even register half the time and my oil pressure is fine. How many miles are on the motor, it could be a sign of weaknes if the gauge is still reading accurately. If you're really concerned there are several people in Pierce County who would be willing to heklp you, if not a local rotary shop. Which seem to exist mostly in Pierce County.
Also, it's common for the filler neck to have that icky substance, but as far as I've read no one has really come up with a reason for why it's there and what causes it... But it's nothing to be alarmed at based on what they've said.
Old Jan 22, 2009 | 03:50 PM
i got the car in november with 86000 on it, it just rolled over to 90251 today. the airpumps makes a loud grinding noise during acceleration and cuts off at around 3800 RPM. and for some reason today, when i was accelerating onto i-5, in 3rd gear, my boost gauge read close to 15.....which i don't think is good, since i've never seen it go above 11. and the car kind of "hiccups" under acceleration.
Old Jan 22, 2009 | 04:02 PM
Upgrayedd's Avatar
Double Dose
If it's grinding then I'm pretty sure you're correct that it's toast. The boost was probably creep because it's 28 degrees outside and the cold weather will cause that. When is the hiccup? Is it when you first mash the throttle or is it during the acceleration?
Old Jan 22, 2009 | 07:16 PM
Upgrayedd's Avatar
Double Dose
I do have an airpump in my parts bin if you're interested. It worked fine when I removed it
Old Jan 22, 2009 | 08:27 PM
i am interested in the air-pump. i was going to eliminate it, but if i don't have to, i won't. it hiccups when i first mash the pedal. i was driving home from work, and normally when i down shift to 4th, it'll take off, but when i did it this time, it hesitated then started to go....but it felt really bogged down. i think the stock intake is screwed up too. when i bought it, the hose with the bov, wasn't connected to the airbox, it was zip-tyed next to the airbox. i was going to re-connect it, but on the opposite side of the airbox has a hose connection, but no hose to go with it. but it ran fine until now, so i wasn't worried about it since i plan on replacing the airbox with CAI anyway.....my idle seems to dip down to around 500RPMs before raising to the normal 900 it usually sits at. but it only does this when i'm stopping....i love this car.....but i hate it at the same time....it's more confusing than my wife.......
Old Jan 22, 2009 | 09:18 PM
Upgrayedd's Avatar
Double Dose
well the bov disconnected from the airbox is nothing to worry about. That is done so you can hear the stock bov vent to atmosphere. The hose on the side is supposedly something for the automatic transmission cars...?? Not sure what or why but that's what I could find cuz mine has a hose but goes to nothing.
The bucking/hesitation is also pretty common. Look in the 3rd gen section FAQ I believe there is something in there that could help you get rid of it. Little adjustments you can make. If you have an aftermarket ecu that's programmable some tuning could also help eliminate that
Old Jan 22, 2009 | 09:26 PM
it just doesn't seem to drive the same as when i bought it....could the air-pump have anything to do with the bucking/hesitation? how much do you want for the one in your parts bin? and also, what in your opinion is the best aftermarket ecu? my car runs quite rich...i need to lean it out
Old Jan 22, 2009 | 09:57 PM
Upgrayedd's Avatar
Double Dose
Apex'i PowerFC is hands down the best bang for your buck. I don't think the airpmp would effect it. You could be lookin at a motor goin out at that mileage. Have it checked. I'll let it go for like $20
Old Jan 22, 2009 | 10:09 PM
zack4173's Avatar
definitely the best aftermarket ECU for the FD has to be the power FC. the bucking my be a throttle control issue or a fuel issue. It could be a lot of things its kinda hard to figure out unless the car is in front of me. Tims right about the engine also you may want to start saving for a rebuild fund mine blew at around 90,000. You are around my neck of the woods also if you want I can come take a look at the car and see if I notice what might be causing the issue. Who did you buy the car from anyway?
Old Jan 22, 2009 | 11:22 PM
i'll definitly have to take you up on the airpump mazdatim, just let me know how you wanna meet up.
zack4173...i'll definitly take your advice on saving for the rebuild, i just wanna make the engine last until early summer, becuz then i deploy and i can do more. i actually bought it in lynnwood from newport motors.....i know....don't by cars from the shady dealer....but i love my fd...almost everything i dreamed it'd be.......minus the issues. but if u wana meet up and take a look at it for i'd appreciate it.
Zach
Old Jan 23, 2009 | 11:09 PM
zack4173's Avatar
I can meet up and check the car out tomorrow ill PM you my number. Im just going to be studying all day. Dont worry I bought my car from the worst dealer on the planet and I still love my car well sometimes I love it lol. I may be able to help with your car I may not I have been through a lot with my car though. Give me a car if you want to meet up. Talk to you later.
Old Jan 24, 2009 | 12:58 AM
johgar's Avatar
Garage_Techno
That doesn't look like helping. Typo?
What's up Zack???
Old Jan 24, 2009 | 08:03 PM
Upgrayedd's Avatar
Double Dose
lol I'm sure he meant call Daniels Altho you never know... Maybe he really does want a car...???
Give me a call Zach, I'll pm you my number
Old Jan 24, 2009 | 08:39 PM
JordanRykon's Avatar
Kunta Kinte's RX7
wasnt that uhh whats his name... Chris aka BlueShift's old fd?
Old Jan 24, 2009 | 08:58 PM
Upgrayedd's Avatar
Double Dose
No I don't think so. Pretty sure his was at Doug's Lynnwood Mazda. Not Newport
Old Jan 24, 2009 | 09:10 PM
Kunta Kinte's RX7
ah okay i remembered it being somewhere up in lynnwood and havin some issues
Old Jan 25, 2009 | 11:19 AM
Upgrayedd's Avatar
Double Dose
The issues, not plural, was a leaky FPD
Old Jan 25, 2009 | 10:18 PM
ok everybody thats helped me out....ie zack and mazdatim.
after learning that my car isn't dying...thanks to zack4173, i'm going to get the power FC and commander, the greddy intake, and if i have enough cash left over i'll get the mid-pipe as well. so when i do get these parts....any advice helps.....so if you can help me....make a suggestion. thanks, Zach
Old Jan 26, 2009 | 01:36 AM
ncastrignano's Avatar
RE for life
glad to see u got it figured out. not sure if ur looking for a downpipe but i have one that i could let go for cheap if your intrested in it. pm me if u are
Old Jan 26, 2009 | 04:26 AM
hansaysso's Avatar
HAN-SOLO
hey zach i have a cheap-o midpipe if you'd like. i could bring it to the next rock-o 7 if'd you like. i don't really have a use for it, and its just rotting in my garage. it hasn't been put on, so its pretty fresh.
Old Jan 26, 2009 | 08:42 AM
Upgrayedd's Avatar
Double Dose
Han Han Han don't offer him parts he can't install! Wait til he gets a standalone before you offer him a midpipe. Zach if you decide to pick up Han's midpipe DO NOT and I repeat DO NOT install it until you have an aftermarket ecu. You'll risk overboosting and blowing your motor
Old Jan 26, 2009 | 08:54 PM
lol...you got it tim....han, i'll take the mid-pipe....i'll be ordering my power fc through rx7.net withing the next few days i'm paying ******* 900 for it, and i'm trusting that its worth the money from what i've been told and the research i've done. i'm getting the apexi intake as well. BUT, i'm just getting all my parts together for when i come back from california in early march. so that when i return, i can just start installing them, so my fd runs better. lol....nothing too crazy....i've been driving my car like a grandma for the past couple of days (as per zacks advice on keeping the boost at low levels)...so the civics on post are getting all happy, telling they're friends they "wasted" an fd....lol....i just want everything to blend into the car when i get back....i probablly won't put too much more into it until after deployment...han, how much for the mid-pipe? and tim....cash or credit? lol
Old Jan 26, 2009 | 10:44 PM
Upgrayedd's Avatar
Double Dose
I accept all major credit cards with remaining balance or exact cash
Old Jan 26, 2009 | 11:10 PM
lol.....i'll just go with cash...and the delivery fee.....well my friend i give you the gift that keeps on giving.....air....have a nice deep breath on me care of mother nature...lol....i'm looking forward to the meet.....i got friday off, so i'll go wax my limping rex......awesome fun....lol.....it'll look fast atleast...
