right plugs wrong hole?!
Old Jan 21, 2009 | 02:57 PM
Zeile's Avatar
what would happen if the spark plugs got reversed '
trailing in the leading
and leading in the trailing
Old Jan 21, 2009 | 03:21 PM
NCross's Avatar
I have a rotary addiction
It would run like crap. Depending on how hard or long you drove it like that it may or may not damage the engine. If it was just for a couple minutes you should be ok.
Old Jan 21, 2009 | 03:41 PM
need RX7's Avatar
Listen to King Diamond.
Do you mean the wires or the actual plugs? If its the plugs, it shouldn't really matter.
Old Jan 21, 2009 | 03:52 PM
iani1.1's Avatar
DILLIGAF
if its the wires wouldnt it misfire? but i can be wrong
be a little more specific
Old Jan 21, 2009 | 04:47 PM
NCross's Avatar
If he puts 9s in the 7 holes and 7's in the 9 holes it will just run like crap. Plain and simple. If the wires are reversed, same situation, but worse for the engine being that the timing and all will be thrown off.
Old Jan 21, 2009 | 04:49 PM
need RX7's Avatar
Really? Are they really that different?
Old Jan 21, 2009 | 05:09 PM
RotaryRocket88's Avatar
Top Down, Boost Up
It will run fine up until the point where the 9s in the leading holes get fouled because they're a colder plug than the 7s. Not hot enough = carbon buildup & eventual misfiring, too hot = melted plugs & detonation.
http://www.ngksparkplugs.com/tech_su...2.asp?mode=nml
This thread really should be in the tech section too.
Old Jan 23, 2009 | 01:17 AM
eff_three_see_es's Avatar
lycanthrope
shouldnt this be in the 2ng gen tech?
Old Jan 23, 2009 | 10:14 AM
francogt1's Avatar
Lots of Hope
i gota get new plugs today they are like $40 a set of 4 right?
Old Jan 23, 2009 | 02:13 PM
20Bforme's Avatar
three spinning triangles
yep
Old Jan 23, 2009 | 04:50 PM
Zeile's Avatar
when you say run like crap do you mean just a big loss in power
or will there be like a noticable jerking or w/e
Old Jan 23, 2009 | 08:19 PM
HAI-TEK7's Avatar
It shouldnt run like crap. I use to run all 9's in my 3rd gen on purpose.
Old Jan 23, 2009 | 08:21 PM
rotorhead_fc's Avatar
Build time
Misfiring will be noticeable. You'll get a really shitty lumpy idle, if at all and if you were to apply any throttle it would also rev up in a similar manner. You may not even be able to take it past a couple thousand rpm which is kinda good as im sure anything past that would be reallly bad for the engine.
Im referring to if the leading and trailing wires were to be mixed up
Old Jan 23, 2009 | 11:18 PM
NCross's Avatar
If you have a hotter plug in the trailing slots and colder plugs in the leading slots it will not run to spec. If you were to run all 9s in leading and trailing it would run ok, but foul out quicker and maybe not have as much bottom end power on a standard NA. If you were to run all 7's then it has an increased chance of detonation.
Old Jan 24, 2009 | 01:16 AM
KhanArtisT's Avatar
Former FC enthusiast
You probably won't even notice a difference...
wstrohm
3rd Gen General Discussion
40
Apr 16, 2016 08:23 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
Project88Turbo
Aug 29, 2015 02:23 PM
