Sponsored by: CARiD
Turning Up the Boost?
Old Jan 17, 2009 | 11:42 AM
RBRotary's Avatar
CA Turning Up the Boost?
should there be any problem i should be aware of if i start turning up boost in my s4 TII? i'm planing on getting a large street port soon and i was wondering what should i add to the port while the housing is out already? any reliablility mods? after the port i'm going to get a turbo kit. any ideas on which ones are good? i want to get the best i could get. but not much turbo lag either.
Any help would be appreciated
Old Jan 18, 2009 | 07:49 AM
manveru's Avatar
sans FD....
ze search button good sir, you must use it.
those are all very broad questions and will net you a ton of different answers. first figure out what kind of goals/ where you want your car to be, THEN read, learn, repeat. and then start wrenching.
best of luck in the build, and fwiw, i say a gt47r. go big or go home!
Old Jan 18, 2009 | 08:09 AM
sunburn's Avatar
Mother****ing Wow
Turn it up as far as you can... just disconnect the vacuum line from wastegate.
Old Jan 18, 2009 | 06:48 PM
dean23's Avatar
pwned
dont be an ***.
stock turbos are no good after 15psi. period.
A-spec sells a gt35r kit. other than that, kit wise, you wont find much. i really depends on your wants and needs for the car.
also take a gader at a few water/methanol injection kits.
Old Jan 18, 2009 | 08:11 PM
RBRotary's Avatar
thanks for the help dean23! most appreciated
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
Jun 26, 2016 10:21 AM
Snook
Aug 15, 2015 08:18 AM
