1st Gen. rim help
Old Jan 12, 2009 | 10:55 AM
spaz13811's Avatar
Newbie
1st Gen. rim help
I'm new here and need some help.
I have a 1979 with an 84 GSL-SE front and rear suspension swapped in. I found a set of 14" x 7j centerline rims in 4x114.3 bolt pattern.
They are an offset of 0. Will these fit or can I make them fit and what size tires can I run ? 205?
If not, is there any other center lines, welds or any solid rims that will work?Thanks for any help !
Old Jan 13, 2009 | 04:52 AM
AntonL's Avatar
Dr. Drift
i know my 1985 gsl-se has the same bolt pattern as an accord, civics are too small, i think its 4x110 but idk for sure, hope it helps
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
