hot start assist question
Old May 20, 2002 | 01:12 PM
minocqa's Avatar
hi
my car doesnt seem to want to start after it warms up.
should i dump the hot start assit system , if i do will the car start ok? or should i try to lube it? wd40 or something.
Old May 20, 2002 | 01:44 PM
mar3's Avatar
Administrator
Pull it out. All it does is pull the accelerator cable when you turn the key. It is meant for the great unwashed that couldn't be trusted to know how to start their new sportscar properly, ie. dummies...change your plugs and see what that does for you. Try two presses of the gas pedal before turning the key...that's basically what the hot start was doing for you when it worked...
Old May 20, 2002 | 02:45 PM
minocqa's Avatar
thanks ...i just didnt want to pull it out then have even more trouble
Old May 20, 2002 | 03:57 PM
where is the hot start assist located?
Old May 20, 2002 | 04:07 PM
mar3's Avatar
Administrator
It's a goofy piece of metal bracket with a little motor on it on the driver's side fenderwell close to the firewall. A cable from it goes to the carb...
Old May 20, 2002 | 06:46 PM
SuperPhly's Avatar
How many of you have taken it out?
Old May 20, 2002 | 07:30 PM
SuperPhly's Avatar
Well mine works and when I went out to find out if it works I discovered that the damn carb is leaking near that cable... ****
Old May 20, 2002 | 09:44 PM
mar3's Avatar
Administrator
A better question is how many rex'rs still have it...not me...
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
