Rotary Drag Racing The place to post your racing stories and info
2009 Imstar Dates and Rules...
Old Jan 8, 2009 | 08:24 AM
enzo250's Avatar
IRS Champion
I copied this from Jason Millers post on honda-tech...
IMSTAR Sport Compact Summer Nationals & Swap Meet (Bring all your used parts to sell!)
Sunday, July 26, 2009
IMSTAR Sport Compact Fall Nationals
Sunday, September 13, 2009
All of this info will be updated shortly on http://www.mirdrag.com/imstar But I didnt want everyone to have to wait on the web guy to make plans. These rules will also be in affect for the World Cup Finals on Saturday and Sunday November 7-8, 2009. Also, on Friday night, May 29, 2009 we will run a special IMSTAR Wild Street class (only Quick 8 though), but class will still pay $1,000 to win, $400 runner-up, and $100 to semis with only a $40 entry fee.
**STREET FIGHTER**
(9.99 and quicker cars only)
Race Format: Quick 16 field, Pro ladder, Heads-up, Pro tree, No breakout
Body: 1987 & newer vehicles only (VW models are permitted to run any year vehicle). Aftermarket body parts are limited to hoods, trunks lids, sunroofs, wings, ground effects, bumpers, and front fenders only. One-piece front ends are not permitted. All other body parts must be stock. No body parts may be removed during competition.
Chassis: Full stock chassis is required. Cutting or drilling for lightening purposes of the chassis is not permitted.
Suspension: Stock type suspension cars only. Aftermarket direct replacement A-arms, struts, and shocks are allowed. Wheelie bars and ladder bars are prohibited.
Street Equipment: Lexan windows are permitted. Interior is not required.
Exhaust: Muffler(s) are required unless vehicle is turbocharged.
Electronics: Two-steps, aftermarket ECU’s, and engine management systems are allowed.
Driveline: Cars originally equipped with independent rear suspension must remain independent rear suspension (IRS conversions to straight rear axle are prohibited). Aftermarket axles, gear ratios, spools, and positive traction differentials are permitted.
Turbocharger: Turbochargers are measured at the inducer wheel diameter at the point where the leading edge of the compressor wheel meets the inlet housing.
Nitrous Oxide: On cars that are not permitted to use nitrous oxide, all nitrous bottles and nitrous/fuel solenoids must be removed off car entirely.
Transmission: Any style automatic transmission permitted. Manual transmission cars are permitted to use aftermarket stock-style clutch-assisted transmissions (no sequential transmissions).
Fuel: Gasoline only permitted. Aftermarket fuel cells are permitted.
Tires (FWD cars): Any size DOT radial tire permitted. Maximum size Slick or DOT Slick is 28.0” x 11.5”.
Tires (RWD cars): Any size DOT radial tire permitted (315/60/15 radials prohibited). Maximum size Slick or DOT Slick is 28.0” x 11.5”.
Tires (AWD cars): Any size DOT radial tire permitted. Maximum size Slick or DOT Slick is 26.0” x 11.5”.
2-rotor cars:
·Engine: OEM block from same manufacturer as car is required. Block may be swapped between different models of same manufacturer. Aftermarket blocks are prohibited.
·Induction: Engine must be EFI. Any style intake is permitted.
·Turbocharger (manual transmission): Limited to 91mm single or 70mm twins. Any type intercooler permitted. May combine with Nitrous.
·Turbocharger (auto transmission): Limited to a 88mm single or 70mm twins. Any type intercooler permitted. May combine with Nitrous.
·Minimum Weight: None
4-cylinder cars:
·Turbocharger (manual transmission): Limited to 91mm single. Any type intercooler permitted. May combine with Nitrous.
·Turbocharger (auto transmission): Limited to a 88mm single. Any type intercooler permitted. May combine with Nitrous.
6-cylinder cars:
·Turbocharger (auto transmission): Limited to 88mm single or 70mm twins. Any type intercooler permitted. May combine with Nitrous.
**WILD STREET**
(10.99 and quicker cars only)
Body: 1987 & newer vehicles only (VW models are permitted to run any year vehicle). Aftermarket body parts are limited to hoods, trunks lids, sunroofs, wings, ground effects, bumpers, and front fenders only. One-piece front ends are not permitted. All other body parts must be stock. All windows must be functional. No body parts may be removed during competition.
Street Equipment: All windows must be OEM glass. Headlights and brake lights are required (one headlight may be removed for air induction). Stock dashboard and full interior from front seats forward is required (both front seats are required). Aftermarket interior and seats are permitted.
Transmission: OEM transmission from the same manufacturer as car is required. RWD cars with manual transmission are permitted to use aftermarket stock-style clutch-assisted transmissions (no sequential transmissions).
Tires (FWD cars): Any size DOT radial tire permitted. Maximum size Slick or DOT Slick is 26.0” x 11.5”.
2-rotor cars:
·Turbocharger (manual transmission): Limited to 80mm single or 60mm twins. Any type intercooler permitted. May combine with Nitrous.
·Turbocharger (auto transmission): Limited to a 76mm single or 58mm twins. Any type intercooler permitted. May combine with Nitrous.
4-cylinder cars:
·Turbocharger (manual transmission): Limited to 72mm single. Any type intercooler permitted. May combine with Nitrous.
·Turbocharger (auto transmission): Limited to a 72mm single. Any type intercooler permitted. Turbocharger cannot be combined with nitrous unless vehicle is equipped with OEM automatic transmission for engine used.
6-cylinder cars:
·Turbocharger (manual transmission): Limited to 80mm single or 60mm twins. Air to air intercoolers only. May combine with Nitrous.
·Turbocharger (auto transmission): Limited to a 76mm single or 58mm twins. Air to air intercoolers only. May combine with Nitrous. (Nitrous prohibited on Domestic V6).
**TRUE STREET**
(11.99 and quicker cars only)
Body: 1987 & newer vehicles only. Aftermarket body parts are limited to hoods, trunks lids, sunroofs, wings, ground effects, bumpers, and front fenders only. One-piece front ends are not permitted. All other body parts must be stock. All windows must be functional. No body parts may be removed during competition.
Tires (FWD cars): Any size DOT radial tire permitted. Maximum size Slick or DOT Slick is 25.0” x 9”.
Tires (RWD cars): Any size DOT radial tire permitted. Maximum size Slick or DOT Slick is 26.0” x 11.5”.
Tires (AWD cars): Any size DOT radial tires only are permitted.
2-rotor cars:
·Turbocharger (manual transmission): Limited to 72mm single or 58mm twins. Air to air intercoolers only. Cannot combine with Nitrous.
·Turbocharger (auto transmission): Limited to 72mm single or 58mm twins. Air to air intercoolers only. Cannot combine with Nitrous.
4-cylinder cars:
·Turbocharger (manual transmission): Limited to 67mm single. Air to air intercoolers only. Cannot combine with Nitrous.
·Turbocharger (auto transmission): Limited to a 64mm single. Air to air intercoolers only. Cannot combine with Nitrous.
6-cylinder cars:
·Turbocharger (auto transmission): Limited to a 67mm single or 56mm twins. Air to air intercoolers only. Cannot combine with Nitrous.
**ALL-MOTOR STREET**
(12.99 and quicker cars only)
Induction: Engine must be EFI. Any style intake or individual throttle bodies are permitted
Chassis: Full stock chassis is required. Cutting or drilling for lightening purposes of the chassis is not permitted. Aftermarket “K” members are permitted on RWD cars.
Exhaust: Muffler(s) are required.
Driveline: Cars originally equipped to independent rear suspension must remain independent rear suspension (IRS conversions to straight rear axle are prohibited). Aftermarket axles, gear ratios, spools, and positive traction differentials are permitted.
Tires (RWD cars): Any size DOT radial tires only are permitted.
4-cylinder cars:
·Power Adders: Prohibited
·Minimum Weight: B series & other series motors - 2050 lbs
·Minimum Weight: K series motors - 2200 lbs
6-cylinder cars:
·Minimum Weight: All series motors - 2100 lbs
**STREET STOCK**
(14.99 and quicker cars only)
Induction: Engine must be EFI. Any style intake is permitted (individual throttle bodies are prohibited).
Transmission: OEM transmission from the same manufacturer as car is required. Aftermarket transmissions are prohibited.
Fuel: Gasoline only permitted. OEM functional gas tank must be used. Modifications to the sump area are permitted.
Tires (RWD cars): Any size DOT radial tire permitted. Maximum size Slick or DOT Slick is 26.0” x 10”.
2-rotor cars:
·Engine: No motor swaps allowed. Engine and cylinder head must have been available for year, make, and model of car sold in USA.
·Minimum Weight: None (due to the wide range of vehicle types and stock type nature of vehicles)
4-cylinder cars:
6-cylinder cars:
**STREET ET**
(Open to sport compact street cars of any ET)
Race Format: ET Bracket racing on a .500 full tree.
Body: Any year vehicles are allowed.
Engine: 2-Rotor, 4-cylinder, and 6-cylinder cars only permitted (8-cylinder, 10-cylinder, and 12-clyinder engines are permitted if it is an import vehicle)
Power Adders: Any power adders are permitted.
Suspension: Stock type suspension cars only. Wheelie bars are prohibited.
Exhaust: Muffler(s) are required unless turbocharged.
Electronics: Two-steps are permitted on manual transmission cars only. Delay boxes, transbrakes, and air shifters are prohibited.
Tires: DOT radial tires, slicks, or DOT slicks are permitted of any size.
**STREETBIKE ET**
(Open to street bikes of any ET.)
Body: Any type streetbike
Engine: 2-cylinder and 4-cylinder engines are permitted.
Suspension: Wheelie bars are prohibited.
Street Equipment: Headlight and brake light is required.
Exhaust: Muffler is not required.
Electronics: Delay boxes are prohibited.
Tires: DOT tires only are permitted.
http://www.mirworldcupfinals.com
Email questions to: jmiller@mirdrag.com
Old Jan 8, 2009 | 08:36 AM
enzo250's Avatar
IRS Champion
I think 2009 is going to be an interesting year
Old Jan 8, 2009 | 10:55 AM
enzo250's Avatar
IRS Champion
Rules, classes, payouts, dates, etc are all updated online..
http://www.mirdrag.com/imstar/
Old Jan 11, 2009 | 08:46 PM
ErnieT's Avatar
Living life 9 seconds at a time
Im glad Jason brought this back. It was a great series in the late 90's and early 2000's. Back in the day it was an combo of Atco and MIR that ran this event.
Old Jan 12, 2009 | 08:06 AM
rotaryB-2000's Avatar
Psalms 37**25
sanctioning bodies or not the OLD school drag racers will be out in full force this year... ..
If you like racing nothing should really stop you from racing..
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
t-von
Sep 10, 2015 01:56 PM
