just went non-seq, why does it sound like i have a cam?
Old May 19, 2002 | 11:38 PM
slopoke's Avatar
ok, i just fired up my car for the first time since i went true non-seq conversion. the car has been down for about a month doing the swap. the car fired right up like it always has then once the idle slowed down, it sounded like the car had a cam in it. it had a really rough idle. what would be the main cause. i will look closer tomrrow, its almost 1 am here so i am to tired to figure anything out, just wanted to know if that sounded realy familiar to anyone else, thanks ,scott
Old May 19, 2002 | 11:48 PM
spooledUP7's Avatar
There and back again
Did you convert your air pump to open atmosphere ? The airpump kind of sounds like that un corked. The funk idle might be in need of an sir adjustment screw turn.
Old May 19, 2002 | 11:49 PM
Rx-Revin's Avatar
Check your map sensor..the vacuum line fell off.
Old May 19, 2002 | 11:57 PM
slopoke's Avatar
my air pump is hooked up jsut like stock. i left the 2nd and 3rd solinoid in place with the wires hooked up for the pump. what is a sir adjustment. ok i will check my map sensor also, thanks for the help, scott
Old May 20, 2002 | 12:01 AM
7-sins's Avatar
thats not paint....
Non-sequential will have a little different sound... I dont think it should be that drastic. I just did the "poor-man's" so I'm not too sure where to look.
Old May 20, 2002 | 12:02 AM
slopoke's Avatar
yea its a real lopy idle, very very noticlble, i wouldnt drive it like this,
Old May 20, 2002 | 12:12 AM
Bacon's Avatar
IRS 4 Life
map sensor....whats your vac reading?, is the idle lumpy stinky as hell and smoking (black) alot? i vote map....
need more details than it sounds funny..heheh
if not could be one of a few things...plugs/wires...and some othet usual suspects
Old May 20, 2002 | 05:27 AM
maxcooper's Avatar
WWFSMD
Going non-sequential defeats the World's Greatest Active Muffler System -- the sequential turbo setup. So your car will be much louder idling and cruising around town. The apparent lope could just be the new sound.
-Max
Old May 20, 2002 | 07:16 AM
slopoke's Avatar
well yes, it gives out little puffs of black smoke with each lope. but i checjed the map and its all hooked up. i am thinking it is my front rotor not firing right, i am gonna pull my plugs and check them out. fired right up this morning and seemed to run smooth until it slowed down and idle at the lower speed. my vacume was reading about 16-17. thanks, scott
Old May 20, 2002 | 07:47 AM
slopoke's Avatar
well, heck, i just cranked it up and it was smooth as butter. thanks for all the help, dont know what it was but its fine now.
Old May 20, 2002 | 11:49 AM
nocab72's Avatar
03 Cobra Killer
I hate those kinds of problems (the ones that fix themselves) cause you never know when they are gonna come back (and they usually do at the worst possible time).
K
Old May 20, 2002 | 12:44 PM
ttpowerd's Avatar
HARRRRRRRRR
Glad to hear you got it running scott! Now when's the hood going to be here?
Old May 20, 2002 | 12:56 PM
SPOautos's Avatar
Hey, where did my $$$ go?
-Max
How much louder are we talking here? What kind of sound is it and why is it louder? I know to do it right you remove the swing door in the exhaust manifold but why would that make it louder?
STEPHEN
Old May 20, 2002 | 01:21 PM
zyounker's Avatar
root
Ok.. Come one people.. It was down for a month.. probably just needed to burn some crap off.. Just keep an eye on it.. and if it starts acting up again, look into it more.
-Zach
Einheri
Oct 7, 2015 12:23 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
