87 Turbo II Feul issues
I can't here the fuel pump coming on. Should it come on when i turn the key to first start it? Also is the fuel pump located in tank or is exturnal? Thanks for your help and if it could be something else let me know and I will try it.......Thanks for your help........Kevin
The car turns won't start and isn't getting any fuel...Yes there is gas in it.....LOL
If you lift up the rear carpet on the driver side there is a silver cover thing that is held on with 4 screws. If you take that panel. off the fuel pump is underneath. Check fuses and wiring before you replace though. It would suck to buy a new one just to find out it was a bad ground or blown fuse.
Frisky Arab
13
Aug 18, 2015 05:30 PM
