clock problem
Old May 19, 2002 | 05:56 PM
rx-7fc's Avatar
clock problem
when you open the door it will turn off and go back to 1:00 or if you start it but if you just turn the power on it will be on and keep time. what might be the problem
Old May 19, 2002 | 08:07 PM
kleach18's Avatar
Just Looking Around
Mine has that same problem. But it happens sometime while I'm driving to.
kleach
Old May 19, 2002 | 08:12 PM
kleach18's Avatar
Just Looking Around
I searched and here's what I found.
http://home.rmci.net/panther/rx7clock.htm
kleach
Old May 19, 2002 | 10:51 PM
rx-7fc's Avatar
i don't think it is the Clock/Warning Light Cluster it might be something else
Old May 19, 2002 | 11:09 PM
kleach18's Avatar
Just Looking Around
Don't really think it could be anything else that I know of. But hey you never know, I'm stumped!
kleach
Old May 19, 2002 | 11:13 PM
rx-7fc's Avatar
it only goes to 1:00 when you open the door or start the car and when you driven it keeps time
Old May 19, 2002 | 11:22 PM
kleach18's Avatar
Just Looking Around
Mine does that sometimes but I think it also does it when I downshift really hard. So that was my problem. You might want to try that. It's not that hard and doesn't take to much time. It's worth a try.
kleach
Old May 19, 2002 | 11:23 PM
kleach18's Avatar
Just Looking Around
I think it's weird that it sets back at 1:00 not 12:00 anybody know why that is????
kleach
Old May 20, 2002 | 12:09 AM
brap brap
That happens to me, I'll set it to the correct time, and as soon as I turn off the car and restart it, it goes back to either 1:00 or whatever it feels like. Not sure what it is either.
Old May 20, 2002 | 12:42 AM
rx-7fc's Avatar
but on mine if you turn the power on it will still have the right time and if you start it will goto 1:00
Old May 20, 2002 | 06:30 AM
turbozetusa's Avatar
defective clock
minor changes in amperage and resistance will affect your clock if it is aged. Mazda really screwed up with the clock and as it ages it becomes much too fragile. There is really no fix for it other than replacement. I tried opening mine and resoldering like I did to fix my airflow meter and CPU but the circuits are just too fragile. Good Luck!
Old May 20, 2002 | 03:17 PM
RETed's Avatar
Re: defective clock
Uh, wrong - every warning cluster I've resoldered worked with the exception of one.&nbsp The owner later confessed he dropped it at one point in time...
I think you need to learn how to solder correctly.
-Ted
Old May 20, 2002 | 03:57 PM
rx302vert's Avatar
try this- when you resolder the beast check the blue electrolitic cap on the back of the pc board. If memory serves me it is 47uf 25v. Replace this,making sure to properly align the neg terminal. Radio shack,$1.99. Worked on one of mine with similar problems.
Old May 20, 2002 | 04:16 PM
MaxRX7's Avatar
hambre y sueño
yeah listen to RETed and if you still have the problem follow rx302vert.
Old May 20, 2002 | 04:45 PM
rx-7fc's Avatar
and if if you try to turn on the lights inside it will turn off and when turn off the lights it goes back to 1:00 and the lights don't work so that is a problem too
Old May 20, 2002 | 05:13 PM
RacerXtreme7's Avatar
NASA geek
Every single clock / idiot light problem (except fuel light once) was fixed buy COMPLETELY resoldering the whole light/clock cluster. I've done LOTS of them, they always work for me. Make sure you remeove ALL old solder (some people just retouch the joints, this only works temperarely because the factory solder is poor quality) use lots of flux and re-solder it, then finally giving a good cleaning with a flux solvent.
Old May 20, 2002 | 05:46 PM
rxse7en's Avatar
Nothing to see here.
Check your fuses too.
B
Old May 20, 2002 | 07:18 PM
JarrardB's Avatar
I Have this exact problem.....and it only started happening when I installed my new CD head unit....
I think I may have a wire or two that Need to be earthed or something...
Now my clock, interior light and factory alarm don't work...
does anyone have a wiring diagram (one that I can actually make sense of) available?
Cheers
Old May 20, 2002 | 10:33 PM
rx-7fc's Avatar
ok i got the lights to work now. it only goes to 1:00 when you start the car so i am going may be re-solder and see if it works
Old May 21, 2002 | 12:59 AM
JarrardB's Avatar
Anyone got that wiring diagram?
Old May 21, 2002 | 03:01 PM
Icemark's Avatar
Here I look and say hmmm this one has a lot of replies I probably don't even have to look at it...
Wrong
Has anyone checked to see if the dome light works???? Should be the fist thing you do!
the dome/room fuse is the same one that keeps the memory on the clock (and the radio, and the ECU, and the AT-EC and the theft unit).
Note the 7.5 amp fuse that runs the dome lights through the L/R wire and all the above and then some:
Old May 21, 2002 | 08:22 PM
rx-7fc's Avatar
what could be the problem with the clock it only goes to 1:00 when you start the car and i changed the fuse for the lights and they work now. the only problem is the clock now so do any of you know what it might be
Old May 21, 2002 | 08:37 PM
Icemark's Avatar
If it only happens when you actualy crank and start the car (and not when you just turn the key on and then back off and then on again) then it is either a bad connection at the clock or a bad battery in the car.
If it happens (as I suspect) when ever the key is turned off then the clock /idoit light assembly is not getting power and you have either a bad/blown/or removed fuse or there is a bad connection at the assembly (which could mean re-soldering or just un plugging and then replugging the assembly).
Old May 21, 2002 | 11:38 PM
rx-7fc's Avatar
it keeps time when you it is off or the car is on but it only goes to 1:00 when you strat the car not when you turn the power on
Old May 22, 2002 | 07:42 AM
Resolder the thing it worked for me on my car too. Very easy to do or get another one off ebay .
fsimeseg
Oct 1, 2015 10:17 AM
erevos
Sep 15, 2015 09:19 AM
