I just installed my fire extinguisher. Pics inside. (56K friendly)
Old May 19, 2002 | 03:42 PM
JONSKI's Avatar
5yr member, joined 2001
This is my inaugural car mod! I think one of my secondaries is leaking, so I installed some piece-of-mind until I can get the occasional fuel smell problem fixed. Just click the picture for a full-size image. You might just want to right-click and select "save target as" so you can browse as you download.
Old May 19, 2002 | 04:54 PM
Nathan Kwok's Avatar
Check your pulsation dampener, this is the most common problem resulting in a "fuel smell" and it WILL cause an engine fire if untreated. Never hurts to have a fire extinguisher, but better to never have to use it. Btw, nice car
Old May 19, 2002 | 04:59 PM
94touring's Avatar
Ok, the second picture is a dog, and the third is a turkey...am I right?
Old May 19, 2002 | 05:01 PM
Mahjik's Avatar
Mr. Links
lol, nice...
I just sit mine in the bin on the passenger side. Out of the way, but still accessible.
Old May 19, 2002 | 05:23 PM
elizer's Avatar
where i live, people put fire extinguishers in their civics, for looks, they get the nice shiney aluminum ones.
Old May 19, 2002 | 05:28 PM
GsrSol's Avatar
Z06 powered FD
2nd one looks more like a duck with it's head bent backwards.
I never mounted mine, just keep it right behind my seat.
Old May 19, 2002 | 05:42 PM
RonKMiller's Avatar
Blow up or win
You REALLY should not drive the car until the source of your "fuel smell" is located and fixed. Many a 3rd gen was destroyed by fuel related fires early on due to problems with hoses. Easy to locate and cheap to fix. Don't delay.
By the time you stop, grab your extinguisher, open your door, pop the hood and IF you can get close enough to release the safety catch it will be too late. Don't forget to bring marshmallows. Quite frankly the extinguisher you have mounted is worthless in terms of capacity and quality. Unless it has a steel (not plastic) neck it will absolutely leak when it gets to be 140F in the interior of your car in the Florida summer heat. It's barely adequate to sit under your kitchen sink. If you are going to buy an extinquisher get Halon, it costs quite a bit more but is exceptionally good at putting out fires in enclosed places - like your interior. They also come in chrome which actually looks pretty nice, or if you are really thrifty, there is always spray paint....
There was a recall on fuel lines and if it has not been done on your car any Mazduh dealer is still required to fix it for you. There should be a sticker on the driver's side door or under hood indicating it was done. You can also call Mazduh with your VIN and they can tell you if it has been done. I do not recommend taking your car to a Mazduh dealer for ANY other reason. They will screw it up really bad.
Hope this helps, although bbq'd noob tastes pretty good! I always like them with a little Chianti!
Old May 19, 2002 | 05:46 PM
tell your friends that its nos!
Old May 19, 2002 | 05:53 PM
RonKMiller's Avatar
Blow up or win
Originally posted by ShawTiMe
tell your friends that it nos!
HAH! You could glue a switch on the bottle, and then run a hose under the passenger seat! Especially if it was Halon you could probably get every one to fall for it..........."Yeah man, that NOS **** is for ricers - I'VE got HALON......"
Old May 19, 2002 | 06:48 PM
Mr. Stock's Avatar
1993 RX7 R1
I have one of those "rice" halon fire extinguishers.
[IMG]http://[/IMG]
Old May 19, 2002 | 07:53 PM
JONSKI's Avatar
LOL @ 94touring!
RonKMiller:
I haven't smelled any fuel for over a week and all the recalls have been done to date. I just drove it for about 40 minutes and did a little boosting above 4500rpm and I still didn't smell any fuel when I sniffed around the UIM. I'm pretty sure that one of my secondaries has a cracked o-ring. Are those o-rings hard to replace? Remember, I have no auto mechanic experience, but I consider myself a quick learner and I have a lot of tools to use at my convenience. I picked this extinguisher up at a hardware store. If I find that it's leaking, then I will surely get the Halon and tell everyone that NOS is for n00bs.
-Jon
Old May 19, 2002 | 09:11 PM
turbo dan's Avatar
Damn dude that's laugh out loud funny.
Old May 19, 2002 | 09:20 PM
94touring's Avatar
I'm glad I got a good laugh out of you guys
By the way Jonski, your interior looks very good. The leather looks to be in mint condition.
Th0m4s
Feb 26, 2019 02:04 AM
astrum
24
Nov 15, 2017 08:44 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
