windshield fluid not shooting out
Old May 19, 2002 | 02:48 PM
trigeek37's Avatar
my windshield fluid is not shooting out onto my windshield. initially the fluid shoots out, then dies off just dribbing out. the resevor is full, and is not leaking. anyone have any ideas why this is happening and possible fixes?
Old May 19, 2002 | 02:55 PM
suprfast's Avatar
one of 4 things.
1) the winshield washer pump could be going bad.
2) you may need to clean out the squirters
3)take of those gay *** cobra eyes and put the stock ones back on
4) you need to switch over to synthetic washer fluid.
kris
Old May 19, 2002 | 03:31 PM
elizer's Avatar
same story for my rear windhsield squirter.
Old May 19, 2002 | 03:35 PM
DK's Avatar
DK
40k worth of fail
Hahahaha ... synthetic washer fluid!
It sounds like the pump since it's spraying intially.
Old May 19, 2002 | 03:49 PM
trigeek37's Avatar
anyone done a washer pump replacement?
where is it for that matter?
and where would I go about getting a new one? my local Mazda dealership?
"3)take of those gay *** cobra eyes and put the stock ones back on" what does this mean, I am confused
Old May 19, 2002 | 04:23 PM
djantlive's Avatar
yeah, what the heck is the cobra eyes?
Stick a tooth pick in the spray nozzels, they are prone to get clogged. After that, look into the washer pump. Don't know more info about the pump but it should be close to the passenger side by the firewall if I had to guess. Check out the parts fiche on mazdaperformance.com to see exact location. Mazdastuff.com, mazdaperformance.com and gallery group are all good discount mazda parts source.
Old May 19, 2002 | 04:44 PM
suprfast's Avatar
cobra eyes. you know those VERY COOL indiglo windshield wiper squirters that every honda and mustang has. the pump is usually located just below or to the side of the resivoir. i imagine it should be an easy swap, then again, this is an rx7. spark plugs took longer than i imagined.
kris
Old May 19, 2002 | 11:31 PM
Sled Driver's Avatar
The Anti-Prius
The windshield washer tank & pump, is located on the drivers side, under the fwd lower half of the fender liner.
You can buy a replacement OEM pump at most auto parts stores for $25-$30. It's one of those parts that is used on other models, not FD specific.
Take about 1/2 hour to replace.
Once you access the tank you will see the pump attached to it.
Disconnect the connector & run a wire from the battery & double check that the motors dead. Hook a meter to the harness connector & check for voltage.
Double check the rubber hose from the pump to the elbow on the hood to see if it's plugged or kinked. I blew the hose clear with a compressor.
You can use a sewing pin to clear & adjust the spray pattern of the nozzles. Tooth picks are too big & soft.
James Knox
Oct 5, 2015 07:56 AM
