Megasquirt how to 0 the timing
Old Dec 28, 2008 | 10:34 PM
elturbonitroso's Avatar
how to 0 the timing
like the tittle said how do you guys 0 your timing in you rotary engines with the ms i know that the first notch in the pulley its 5atdc but i belive that the ms1 chip dont go 5 in the fix angle so what do you guys used.thanks
Old Dec 29, 2008 | 10:13 AM
Aaron Cake's Avatar
Engine, Not Motor
Set the fixed angle to -5. Connect up timing light, start car, adjust CAS until pointer lines up to leading (yellow) timing mark. Now set fixed angle back to the map (-10 I think). Timing is zero'ed.
Old Dec 29, 2008 | 11:05 PM
muythaibxr's Avatar
MegaSquirt Mod
-10 means use the map like Aaron said.
Ken
Old Dec 30, 2008 | 01:27 PM
fix angle need to be 5 deg or -5 to 0 the timing and them set it back to -10 to the ms fallow the spark table.hey ken i think this needs to be in the faq.
Old Dec 30, 2008 | 02:10 PM
pmrobert's Avatar
It's already in several places on megamanual.com, msefi.com and msextra.com; Let Ken spend his well appreciated time towards code generation. That said, you're right, the FAQ could use a freshening - any technical writers out there?
-Mike
Old Dec 30, 2008 | 07:56 PM
i know thats hes been very busy working in the ms2xtra.maybe somebody else could refresh the faq.
Old Dec 31, 2008 | 10:01 AM
muythaibxr's Avatar
MegaSquirt Mod
I didn't put it in the FAQ because I thought it was obvious that you need to set the timing to the same as the mark on the wheel, and then turn the CAS to zero the timing.
The dialog where you do that says set -10 to use the map.
Also, it's not 5 or -5, you have to set it to -5.
Ken
Old Dec 31, 2008 | 05:09 PM
ok got it.
Microtech
30
Apr 23, 2016 06:37 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
incubuseva
14
Sep 3, 2015 12:37 PM
20B Forum
Aug 19, 2015 01:47 PM
