Haltech installing resistors for low imped injectors
Old May 19, 2002 | 09:44 AM
rex's7's Avatar
hi guys iwant to put resistors on inline with my low imp 1600's to match my high imped primaries...how do i exactly put the resistor? the 12v source to the injector?
thanks!
Old May 19, 2002 | 12:38 PM
RETed's Avatar
Uh, we're in the Haltech section, right?
The Haltech has no problem pushing either one low-impedence fuel injector or up to a pair of high-impedence fuel injectors on a single fuel injector channel.&nbsp Read your manual...
-Ted
Old May 20, 2002 | 05:13 AM
HWO's Avatar
HWO
inteligent extratarestril
hmm actually if you check out the manual you'll see that you can ACTUALLY run 2 LOW impendence injectors or 4 HIGH impendence injectors PER driver.........
Old May 20, 2002 | 04:26 PM
RETed's Avatar
Manual version?&nbsp I've got 1.0 - yeah, it's old; I know there's later revisions out there...
Appendix C
C.1 The E6K Injector Drivers
The solid state devices within the E6K ECU that are used to switch the injectors are known as the <EM>injectors drivers.</EM>&nbsp The E6K possesses eight heavy-duty injector drivers and can use either saturation or peak-and-hold injectors.&nbsp Each individual driver limits its current draw to 4 amps, and, upon reaching that limit, clamps the current to just 1 amp.
The drivers used in the E6K are each capable of firing two saturation injectors.&nbsp Individual drivers are capable of firing one or two 2/0.5A peak-and-hold injectors.&nbsp If using 4/1A peak-and-hold injectors, you should not employ more than one injector per driver.&nbsp Most high current motorsports injectors can also be fired (one per driver) providing fuel pressures are not excessive (>5 bar).&nbsp Running two high current, low impedence injectors from one driver can result in difficulty in obtaining stable air:fiel ratios when injection times are short (around idle and light load).
In general, an injector driver will reliably fire two injectors with more than 2.5 ohms coil resistance.&nbsp Coil resistance can be measured with an ordinary low-ohm resistance meter.&nbsp If you are unsure with E6K model to choose contact your Haltech dealer for advice.
NOTE:&nbsp Under no circumstances should you mix saturation and peak-and-hold injectors on the one driver.&nbsp This will lead to erratic injector operation.
That's taken verbatim from my E6K manual, Verison 1.0...
Most of the "stock" fuel injectors the RX-7's I've come across usually spec out to about 2.0&#937 - this is too close to the 2.5&#937 spec the manual mentions, and I would not want to risk killing the motor due to erratic fuel injection delivery due to the built-in current clamp.
Even with resistances as high as 3.0&#937, I would be wary...
I=V/R
I=12.0V/3.0&#937
I=4.0A
That makes it a 4.0A potential current load.
You're right though - it does say it's okay to run a pair of low-impedence fuel injectors.&nbsp I'm paranoid with electrical systems, so I tend to err on the safe side...
-Ted
Old May 21, 2002 | 01:08 AM
HWO's Avatar
HWO
yeah page 75 of the manual i have - version 9.0 from march last year
Queppa
Nov 18, 2024 03:47 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
