Noob and got hesitation at 4 rpms
Old Dec 26, 2008 | 11:36 AM
bcastillo132's Avatar
10th ae rx7
Unhappy Noob and got hesitation at 4 rpms
I got a 86 RX7 and has hesitation at about 4 rpm. I switched the maf and still hesitated. Then i swaped the injectors and now it sounds like a bolcking sound goin past 4rpm? Need help if you know anything plz let me know.
Old Dec 28, 2008 | 08:00 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Is it just a hesitation? Or will it not go past 4k at all? If the first, try adding an extra ground between the pressure sensor and the chassis. This fix was in a mazda service bulletin for '86 models.
Old Dec 28, 2008 | 09:23 PM
10th ae rx7
The blocking slowes it down so it really wont let it go past it but if i slowly step on it, it will pass but with hesitation.
Old Dec 30, 2008 | 01:16 AM
Top Down, Boost Up
Sounds like the secondary injectors may not be firing at all. At 3800 rpm, primary injector duty is cut in half & the secondaries are supposed to match them. If they do not come on, you will effectively get a fuel cut at 3800.
The quick and dirty check is to unplug both of the secondary injector clips and take it for a drive. If the behavior doesn't change, it's safe to assume the secondaries aren't doing anything at all.
Old Jan 1, 2009 | 08:27 PM
REsuperOG's Avatar
7777777
this problem is the most common with FC's.
a stand alone engine management system is by far the best way to go to deal with this. however, if it is "overkill" for one to purchase that, start re-doing all your grounds.... yes... ALL OF THEM
dona1326cosprings7
Oct 29, 2015 06:47 AM
RX200013B
Haltech Forum
Oct 12, 2015 09:45 PM
eplusz
15
Oct 7, 2015 04:04 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
lnlreaper
Sep 27, 2015 09:59 AM
