GT 35/40 specs
Old May 18, 2002 | 02:02 PM
SilverR1's Avatar
GT 35/40 specs
I'm new to the single turbo scene and I'm unsure of what all the specs mean. Could somebody explain to me the significants of these number and what that means to me? Also how does the GT 35/40 compare the other turbos out there. For example the T04s or the 60-1?
1.06a/r Turbine Housing, single entry, 4-bolt outlet
84 Trim Turbine Wheel, 2.45/2.68
Water cooled GT centre housing
0.70a/r Compressor Housing, 4' Inlet, 2.5' Outlet
56 Trim Compressor Wheel, 60lbs/min flow, 2.41/3.22
Old May 18, 2002 | 11:15 PM
mmonaco's Avatar
Part out my Car
i can anwser a few of these if i am thinking correctly. OK the 1.06 a/r is the size of the turbo where the exhaust goes out. A/R Stands for Areas radias. Water cooled mean the turbo uses water to cool the the moving parts.I really not 100% sure on the other ones. Hope that helps. Ohh ya go to amazon and get the book called maxium boost by corky bell, great book and explains all the aspecs of tubocharging car. Marc
Old May 19, 2002 | 12:39 AM
stevecod's Avatar
Re: GT 35/40 specs
do a search under gt 3540 or A-spec and you should find the infos you need. Sean, at A-spec tunning explained the specs of that turbo in details.
Rotary12Ahead
Oct 29, 2015 03:16 PM
edgars95rx7
Link Vi-PEC
Oct 1, 2015 01:59 PM
