JDM FTP wiring help
Old Dec 18, 2008 | 01:11 AM
lele73's Avatar
15U24
JDM FTP wiring help
Ok so I have hooked up my FTP lights to my turn signal lights..... DIM!!! How can I make it so my FTP lights Just as bright as my head lights????? is it possible??? LMK
Old Dec 21, 2008 | 05:37 AM
lele73's Avatar
15U24
LED's might help? Anyone?
Old Dec 21, 2008 | 07:20 AM
REVERE's Avatar
defenestrated
Why? you are not planing on using them as driving lights are you?
LED would be your best bet and I have seen a few guys in the club who have done it
Old Dec 21, 2008 | 01:10 PM
lele73's Avatar
15U24
no i don't want them as headlights, i just want the to be just as bright. i am going to look for a set of LED's today and see where that goes . thanks :P
Old Dec 22, 2008 | 10:34 AM
Aaron Cake's Avatar
Engine, Not Motor
Connect them to a good source of 12V through a relay (connect to the battery via a fuse), then switch the relay with your IGN or turn signal 12V.
Old Dec 26, 2008 | 01:47 AM
lele73's Avatar
15U24
the driving lights on the turns are not a 12v source are they? i need to get my meter out and test. there still too dim for me. i need brighter!!!!
Old Dec 27, 2008 | 06:21 PM
lele73's Avatar
15U24
going to meter it now
Old Jan 2, 2009 | 11:13 PM
lele73's Avatar
15U24
ok LED's didn't do anything but COPS seem to watch me more. How can i get my FTP lights to shine as bright as my headlights? i metered the volts coming out of the bulb. fogs are like 11.58 and the regular markers are 10.57. i haven't measured the headlights themeless yet. I'll have to build harnesses... damn. can anyone help me here?? i'm so lost.
and again o can fix anything the ARMY throws at me. but electronics? damn i need to be walked by hand in that field. i have a few relays, but i get the dear in the headlight look at drawings. and i'm super lazy to look up the wireing diagram to figure out which is the ignition and what not. help me please
Old Jan 3, 2009 | 10:15 AM
Aaron Cake's Avatar
Engine, Not Motor
I've already given you the answer. Run them directly through the battery with a relay. Trigger the relay from whatever source you want (headlights, marker lights, etc.). The FTP lenses will NEVER be as bright as the headlights as they are not designed for that purpose. They are a low wattage bulb without any reflector.
_Tones_
May 25, 2021 05:37 AM
The1Sun
Sep 7, 2015 10:21 PM
