Microtech 2 Step on LTX12S
Old Dec 14, 2008 | 08:20 PM
13BT_Starlet's Avatar
2 Step on LTX12S
Hello , I have a LTX12S and I have been reading about the 2step/launch control and on some MT ecu it cuts fuel instead of ignition but not sure on which ones and I would like to know if it cuts ignition instead of fuel on my particular ECU .
Old Dec 18, 2008 | 08:29 PM
where are all the MicroTech Guru's at ? Help PPL
Old Dec 19, 2008 | 07:02 AM
rx72c's Avatar
Top Answer: 1
It depends on what the ecu was originally programmed for.
Im pretty sure their is an option to change it, i will check my books tonight and post back.
Old Dec 19, 2008 | 07:36 AM
Ok I thank you , because in the manual i don't say and I keep hearing ppl say the only cut fuel and others say ingnition .
Old Dec 19, 2008 | 05:02 PM
rx72c's Avatar
Top Answer: 1
The microtech 2 step is very basic.
It is not an igniton cut or a fuel cut as far as i can see.
When you activate the "2 step"
You can dump a shitload of fuel and retard a heap of timing and also put in a rev cut all on the one input, all of which would bring boost up and this would be a primitive 2 step.
I hope this clears things up for you a little.
Also as far as i can see the revcut is a fuel cut and not an igniton cut.
Id dare say that if you wanted an igniton cut you had to request it on order.
I have gathered from doing a quick read in the advanced microtech manual next time i am down at microtech i will ask and see what the verdict is on it 100%
Old Dec 19, 2008 | 09:10 PM
Thanks Alot rx72c , keep me posted after the microtech visit .
Old Dec 23, 2008 | 10:37 AM
jacoolv6's Avatar
"Street Ported"
Quick question is the lt10 come with a 2 Step and if those is it easy to hook it up what would I need?
Old Dec 23, 2008 | 05:47 PM
If I'm not mistaking all LT's have this option , its the blue/red the Aux input wire hook it to a push switch with 12v and set up the rpm,timing,fuel you desire on screen30 under the Revlim option.
Old Dec 29, 2008 | 05:52 AM
jacoolv6's Avatar
"Street Ported"
Another question does the OMP still work with a Microtech?
Old Dec 29, 2008 | 03:57 PM
rx72c's Avatar
Top Answer: 1
No it does not.
Old Dec 30, 2008 | 10:18 AM
jacoolv6's Avatar
"Street Ported"
Hey rx72c
What would be a good premix ratio with the omp remove?
Old Dec 30, 2008 | 04:25 PM
rx72c's Avatar
Top Answer: 1
100:1
Old Dec 30, 2008 | 05:20 PM
jacoolv6's Avatar
"Street Ported"
That like 1oz to 1 gallon?
Old Dec 31, 2008 | 01:09 AM
rx72c's Avatar
Top Answer: 1
not use to american terms
So for a 45l tank
put 450ml of 2 stroke.
Old Dec 31, 2008 | 10:10 AM
BluRR's Avatar
Anybody successfuully use the 2 step feature here? What were the parameters you used? What redline? How much timing you pulled? and How much gas you added? What kind of boost did it net you at the launch?
Old Dec 31, 2008 | 04:39 PM
rx72c's Avatar
Top Answer: 1
On low hp cars i have tried it and it dosnt work very well.
On high hp cars it tends to leave you with a front plate in many pieces.
Old Jan 1, 2009 | 12:03 PM
BluRR's Avatar
Why? Do you think its something you are not doing right? Not enough fuel..not enough timing retard?
Old Jan 1, 2009 | 04:21 PM
rx72c's Avatar
Top Answer: 1
It could be.
I have tried various combinations and nearly all the time, after a few uses of it the plate is shattered.
ANd i have seen various other big name shops end up with the same problem, and change the ecu to motec and not have any problems. I am in the process of changing my car over to motec to see if i can stop cracking front plates.
Old Jan 4, 2009 | 08:40 PM
BluRR's Avatar
I guess I better scratch that off my "Things to do List" for now...
Old Jan 4, 2009 | 10:58 PM
myfc3s's Avatar
That's what she said...
Why not try an MSD ignition with a 2step module. I have one and it brings up the boost at launch. And from what RX72c says, i used the Microtech revlim and was not happy with it.
Old Jan 5, 2009 | 06:08 AM
rx72c's Avatar
Top Answer: 1
The MSD 2 step works well from what i have heard but i dont like their ignition boxes for other reasons.
Old Jan 5, 2009 | 04:44 PM
BluRR's Avatar
I have a single MSD 6AL box
Old Jan 5, 2009 | 08:32 PM
Whats the reason you don'tcarefor them ? did you have one fail on you ? Alot of the fast cars in PR and USA are running them on there rotary's . I see them using the DIS2 & DIS4 .
Old Jan 6, 2009 | 07:24 PM
myfc3s's Avatar
try it
You Should try it bro, purchase one on ebay for like 40-50 dollars and hook it up.
At first i was not sure what the outcome was, but as soon as i installed one on my 6AL...instant boost on high rev.
Old Jan 6, 2009 | 09:19 PM
BluRR's Avatar
It can work with a single 6AL box?
