low compression
Old Dec 14, 2008 | 10:54 AM
kamadle's Avatar
CA low compression
i have a 93 13b single turbo with 14.9 psi boost. the front rotor has 100psi and the rear has 40psi. How bad will it be if i keep driving it until i get a new motor
Old Dec 14, 2008 | 08:27 PM
dgeesaman's Avatar
If it's a bad apex seal, you probably already shredded your turbo and trashed your rear housings. I would park it just in case it's not. Further driving can only make a bad situation worse.
Old Dec 15, 2008 | 12:25 PM
kamadle's Avatar
why would the turbo be shot? from a broken piece of the seal.
ZacMan
Sep 19, 2015 09:20 PM
BLK 93
11
Sep 9, 2015 10:56 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
