1985 rx7 miss firing or vacuum leak?
Old Dec 13, 2008 | 04:36 PM
BAMBAM11336's Avatar
bambam
FL 1985 rx7 miss firing or vacuum leak?
feels like misfire but is it vacuum leak,wont idle under 1100 and rpm's lope?
Old Dec 14, 2008 | 10:47 AM
Aaron Cake's Avatar
Engine, Not Motor
So check for vacuum leaks. The vac diagrams are in the FSM. Spray some water around the area you suspect is leaking and listen for the engine to change tone as it sucks in the water.
Old Dec 14, 2008 | 11:48 AM
bambam
i did,but i used starting fluid sprayed around all vacuum lines every were and no change in idle to find leak.it should rev when it sucks in starting fluid.
Marty RE
Aug 29, 2015 07:51 AM
gtcd
30
Aug 19, 2015 02:44 AM
pzr2
Aug 15, 2015 08:29 PM
