Carbon free REW13B
Old Dec 13, 2008 | 09:05 AM
userjh5174's Avatar
Thumbs up Carbon free REW13B
Mr. Coleman, What is the best way to keep the rotary (REW13B) engine carbon free?
Old Dec 13, 2008 | 09:37 AM
Turbo23's Avatar
Panda Bear
dont drive it
Old Dec 13, 2008 | 09:42 AM
Tom93R1's Avatar
gross polluter
Convert it to run propane
Old Dec 13, 2008 | 09:56 AM
jantore's Avatar
There are several ways. Water injection, Water/meth injection, meth injection or convert your engine to run on E85
JT
Old Dec 13, 2008 | 12:10 PM
Falken's Avatar
DIY Tubine Guy
Dunno about the 13B, but us Rennies always say "a redline a day keeps the carbon away"
Old Dec 13, 2008 | 12:22 PM
streetRx7's Avatar
Originally Posted by Turbo23
dont drive it
LMAO
Old Dec 19, 2008 | 01:45 PM
jkstill's Avatar
Searching for 10th's
Though I haven't done it myself, convert to no OMP and mix 2 stroke oil with gas.
Or use an adapter from Rotary Aviation to pump 2 stroke oil with the OMP.
Burning engine oil is a major contributor to carbon buildup in rotary engines.
Old Dec 19, 2008 | 10:46 PM
cewrx7r1's Avatar
Eye In The Sky
Lean out the idle and cruise area of your map as much as posible.
Old Dec 20, 2008 | 12:36 AM
Narfle's Avatar
Rx7 Wagon
premix and delete omp.
Old Dec 25, 2008 | 01:09 AM
Monkman33's Avatar
Goodfalla Engine Complete
AI at least 50/50 water
Old Dec 27, 2008 | 02:18 PM
BLUE TII's Avatar
Rotary Motoring
Disable EGR, evaporative/crankcase emissions and run a good premix.
I run 50:1 ratio (No, doesn't smoke) Quicksilver premix and Lucas Top End Lube/Injector Cleaner instead of premix every once in a while to keep the injector tips clear.
If you keep the stock oil injection (as I did) keep the engine oil very clean.
Very clean engine inside, even the exhaust ports will be carbon free if you port to positive relief. Just a dusting of carbon on exhaust port sleeves, turbo/manifold.
This is important for best performance and reliability as it eliminates carbon build up in apex seal groove and subsequent sticking of apex seal as it crosses the minor axis which leads to early ignition of the charge in the compression phase.
Mazda found high rpm horsepower gains from eliminating this apex seal sticking in the Lemans car by using specially formulated clean burning Idemitsu premix.
Old Dec 28, 2008 | 10:10 AM
userjh5174's Avatar
I agree BLUEII, Idemetsu worked wonders on the 787B car.
Thanks
