Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
2 things
Old Dec 11, 2008 | 01:11 PM
chacemeh's Avatar
rotors, my anti-piston
2 things
1. upon purchasing my N/A, what are some things i should inspect or replace when i get it.
2. does anyone know anything about installing extra gauges? wiring schematics, anything?...
Old Dec 11, 2008 | 05:20 PM
fidelity101's Avatar
Rallye RX7
I'm sure a lot of people know things about extra gauges and wiring and anything else.
Old Dec 11, 2008 | 06:42 PM
diabolical1's Avatar
not sure if this is the right place for this. perhaps the new member section.
1. check common-sense-stuff like your fluids and brakes. replace anything that seems suspect. i usually change fluids when i buy a car regardless of what the previous owner tells me. make sure your OMP is working or that you're premixing. do a full tuneup.
2. that's a vague question. you'll need to specify what auxillary gauges you plan to install. wiring would be pretty straightforward, again, depending on what you're installing.
Old Dec 11, 2008 | 08:44 PM
chacemeh's Avatar
oil temp/pressure, boost
where do i drill for all of those and how do wire them best
Old Dec 11, 2008 | 08:58 PM
why drill anything? why don't you just get an adapter from Racing Beat?
Old Dec 11, 2008 | 09:59 PM
chacemeh's Avatar
let me re-phrase that...
where do i install the sensors for the gauges?
Old Dec 12, 2008 | 03:21 AM
rnz520's Avatar
No Pistons
search bar son, hell google it
Old Dec 12, 2008 | 11:50 AM
dude, go to RB's site look at their adapter blocks (there are 2 of them) it will be readily apparent where the sensors go. no drilling involved.
Old Dec 12, 2008 | 03:36 PM
chacemeh's Avatar
lord this is all beyond me, RB? im sorry, i need this more in lamen's terms.
Old Dec 12, 2008 | 04:16 PM
RB = Racing Beat
since you don't have the yet, don't worry about it. the stock gauges may not be the MOST accurate devices in the world, but they're usually just fine for stock or lightly modified setups. when you get the car and get it all sorted out then you can get the adapter block and run aftermarket pressure and temperature gauges from it.
Old Mar 6, 2009 | 08:17 AM
xFCdrift3Sx's Avatar
As for wiring diagrams just pick up a haynes repair manual or an FSM, they have both helped me sort things out many times. Heres a link to the tech section of rx7city.com, not the best site in my opinion but im damn gald the posted the FSM so its at easy reach. http://rx7city.com/techconnect.htm
Old Mar 6, 2009 | 11:29 AM
farberio's Avatar
NASA-MW ST4
Try this.
http://www.mazdatrix.com/boil3.htm
Go to the bottom of the page, blue thing that sits in between your oil filter and the engine.
Old Mar 7, 2009 | 06:45 PM
KillaKitiie's Avatar
Bongolio
Check your PD for a missing screw or leak's. Just to be sure.
ZacMan
Sep 19, 2015 09:20 PM
Tem120
Sep 7, 2015 09:53 AM
