93fd fuel cut off
Old Dec 9, 2008 | 11:49 AM
ajnybo's Avatar
Newbie
93fd fuel cut off
so i have a fd and when i hit 5,500 rpm why fuel cuts off. why does it do this and how can i change it?
Old Dec 9, 2008 | 10:19 PM
K3VIN.L's Avatar
well im not much of a technician but i've experienced the same thing with my FD only at 4,000rpm. when you start it up, let the engine warm up so the temp needle is almost halfway ( thats where mine sits anyway cause i have a good cooling kit ) because the car knows not to boost an engine thats cold. and when its warm enough and want to boost, slowly give it gas up to the cut off point, then let off and rev it up again, and just slowly let the rpm needle pass that point, then bring it back down then it should be good to rip. well thats what i do anyway, but like i said im not a tech, just wanted to put in my 2 cents
Old Dec 10, 2008 | 04:06 AM
dgeesaman's Avatar
What boost are you at when you get cut off?
(If you don't know, I recommend you install a boost gauge even temporarily)
alphawolff
Nov 17, 2015 05:57 PM
Snook
21
Sep 1, 2015 06:32 PM
armans
Aug 15, 2015 09:08 PM
