Alcohol Injection Vs E85 Ethanol
Old Dec 8, 2008 | 09:49 PM
darkphantom's Avatar
The king of the highway!
just want to get your opinion on alcohol injection vs E85 ethanol
from what ive seen on E85 ethanol there are some good and bad sides to it
Good! Cooling properties,
octane rating
proven to add horsepower and horsepower curve
Able to run higher boost and get it from the pump
As expensive as getting gas from the pump station
BAD! Need to run 30% more fuel which means bigger injectors = gas mileage
Locations to find e85 ethanol
Bigger fuel pumps or more fuel pumps
when you run out of fuel and can only use pump gas the car will run very very rich
And then theres alcohol injection
Good! Cheaper to setup than ethanol (just have to get the methanol/WI and the kit vs the fuel injectors and the fuel pump)
More boost (600hp proven)
Doesnt drain as quickly as ethanol (one 2 gal tank last as much as a tank of gas)
BAD! when you run out how will you know if you dont have a fail system
what if the nozzles burn from inside the car and your running without the system
So i just want to get you guys though on those 2 cause it seems that people are looking for alternatives besides racegas as its $60 for 5 gal of c116
Old Dec 21, 2008 | 11:59 PM
spanks13's Avatar
methanol still burns much quicker than gasoline, and requires a much richer mixture.
Old Dec 22, 2008 | 12:16 AM
Gorilla RE's Avatar
GorillaRaceEngineering.co
octane rating
Both......but add water to the mix.
-J
Logan Reinisch
44
Sep 17, 2018 12:20 PM
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
