West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
S4 intake manifold to s5 conversion
Old Dec 4, 2008 | 10:06 PM
TurboIILover's Avatar
i just wanted to know if it can be done.. what needs to be changed and is it worth it...ive heard that some people that run in scca ITS spec rx7's convert to the s5 manifold if they start off with an s4...ive search and have come out empty handed..thanks
ismael
Old Dec 4, 2008 | 11:11 PM
Siraniko's Avatar
RX for fun
yes
Old Dec 4, 2008 | 11:12 PM
what do i need to do the conversion?? s5 harness?? s5 ecu??
thanks
ismael
Old Dec 4, 2008 | 11:24 PM
myfc3s's Avatar
That's what she said...
no
thanks
ismael
You can just use the S5 lower and upper intake manifold. You will also need to use the S5 Prime and secondary fuel rail. Everything else would work and some with minor modification to fit correctly.
Old Dec 4, 2008 | 11:36 PM
iLikeEatPoo's Avatar
The Great Dick
If you change the fuel injectors doesn't the wiring harness need to be changed too?
Old Dec 5, 2008 | 12:06 AM
well he sait just to change the fuel rails so i think it should be fine anyway i think the injectors are the same correct me if im wrong.... what do u mean by minor modification??
thanks
ismael
Old Dec 5, 2008 | 02:48 AM
if dont dont use the middle section would it still be worth the trouble?
Old Dec 5, 2008 | 05:17 AM
The Great Dick
the fuel injector clips on the wiring harness from S4 to S5 are different is what I'm saying.
If you want the swap I have a S5 harness ecu intake manifolds & fuel rails available.
Old Dec 5, 2008 | 11:36 AM
oh ok gotcha lol
Old Dec 5, 2008 | 08:37 PM
fc3s91's Avatar
R.I.P Mark( Icemark )
This has been covered more than once. Here you go:
http://howto.globalvicinity.com/gv_w...i=63&co=1&vi=1
DerpyToast
14
Nov 23, 2024 05:19 PM
rgordon1979
40
Mar 15, 2022 12:04 PM
mulcryant
Sep 9, 2015 05:24 PM
