Another heater problem
Old Dec 4, 2008 | 05:45 PM
AE8616v's Avatar
OGX3
Have a problem with my heat. nothing happens at all when i turn it on. my logicon lights up except for the lights to select were the heat goes, the heater fuse is fine, and i get no noise from the air mix motor? i have an 88 vert i live in chicago so with out the defrost i can barley see were im going half the time. i saw another thread of some one who had the same problem but they didnt say what they did to fix it... some one help me out.
Old Dec 5, 2008 | 09:21 AM
Aaron Cake's Avatar
Engine, Not Motor
Cold solder joints in the logicon.
Old Dec 5, 2008 | 01:14 PM
AE8616v's Avatar
OGX3
aight im gonna pull it apart tommorow and redo the solder thanks for ur help. its like below zero right now here in the mourning
Old Dec 7, 2008 | 09:08 AM
AE8616v's Avatar
OGX3
i tried redoing the solder but it still doesnt work, right before it broke on the max setting it made a loud ticking sound could it be the resistor? but my air mix motor doesnt work either so. i was thinking about running the blower motor with a switch and a inline fuse because i really need heat...
Old Dec 7, 2008 | 10:16 AM
driftmagic1's Avatar
it may be a relay , esspecialy if you heard clicking
Old Dec 7, 2008 | 10:20 AM
Aaron Cake's Avatar
Engine, Not Motor
Have you tested the motor itself?
Old Dec 8, 2008 | 11:27 AM
AE8616v's Avatar
OGX3
i'm gonna test the motor today and if it was the relay wouldn't the air mix motor still work
Old Dec 8, 2008 | 12:41 PM
talkstometal's Avatar
i have motor, logicon, and main heater housing for sale and live just south of chicago. if you need pieces pm me.
Old Dec 8, 2008 | 10:44 PM
to be perfectly honest i dont know because i havent mess with much wiring on rx7's and im not sure how it is wired but most likely they would be on close but different circuts
Old Dec 10, 2008 | 11:33 AM
AE8616v's Avatar
OGX3
do i need to take the whole dash apart to test the motor cause i tryed just taking off the glove box but i couldnt really get at it
Old Dec 10, 2008 | 06:29 PM
AE8616v's Avatar
OGX3
never mind i figured it out and it does work
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
Hipsiguy
Sep 14, 2015 05:25 PM
risingsunroof82
Sep 7, 2015 01:11 PM
