wiring (painless)
Old Dec 4, 2008 | 04:29 PM
kingbob1000's Avatar
NC wiring (painless)
I was wanting to get rid of the old main harness since I use virtually nothing on it. I want to be able to use my power window, brake lights, headlight, turn signals, flashers, the basics and get rid of all the rest. However I am a novice when it come to wiring and I just want it all gone since the car is getting a frame up restoration (or unibody) for the picky. I was just wondering if anyone else has had any experience with this i would really appreciate it. And yes the wiring sucks and there are shorts and 5 or more wires melted together.
thanks in advance
shane
Old Dec 4, 2008 | 05:11 PM
IanS's Avatar
Ricer
Probably the best way is to de-pin the plugs. If you ask around locally I am sure you can find someone that can do this for you. Much safer than cutting as you cant uncut a wire but you can re-insert the pin in the plug.
Old Dec 6, 2008 | 10:11 PM
mrenns34's Avatar
Drift_FC
Ya I would Find some one to do it for you I tried to piece my harness together and ended up screwing me i turned my ign. and it would turn over i finally just got a hole new harness
Old Dec 7, 2008 | 03:42 PM
NC update
everything is going to be new on the car and i hate to put that old b/s harness back in there.
Old Dec 7, 2008 | 05:51 PM
mrenns34's Avatar
Drift_FC
Honestly though when do you ever see the harness you know what i mean. also you could get the colored cover to go around it make it look better you have a color scheme under the hood like vac hoses fuel radiator
Old Dec 8, 2008 | 01:58 PM
hey
well I thought the same thing I was just looking for a dependable way because this is a 10 grand rebuild and I am not doing it again. I guess I will be in the market for an s4 wiring harness without defects and just lay it back in. This car is also getting a new sheet metel dash so i guess i will just have extra wires.
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
