!Help! rusted bolt...technique anyone?
Old May 16, 2002 | 10:16 PM
darkwaveboi's Avatar
Need donor car in Fairfax
oh man, im in a bit of a rough spot. I was unbolting the cat, and got 3 bolts off, (one with hack saw), and im down to the last bolt, its rusted on, has a stripped head, and......the hacksaw blade is dull. I have another blade SOMEWHERE but that isnt happening tonight.
Without using any type of air tool (too late..neighbors) and without a blow torch or heat gun, what do you all suggest i do? (got all basic tools)
Old May 16, 2002 | 10:24 PM
Bambam7's Avatar
I came, I saw, I boosted.
I don't see what you can do.
Geez, if the head is stripped, and it frozen on, and all you have are hand tools????
You can do many things though.... like tack weld/braze a box end wrench on it.... cut it off with a hacksaw... whatever... but nothing with a few simple hand tools besides getting a good grip on it with vise grips or something, banging it with a hammer... using penetrating fluild... whatever...
Old May 16, 2002 | 10:27 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Try this
If you have a really small pipe wrench and some WD 40, and a wire brush you hook onto a drill, you might still get it off.
First, brush off as much of the rust with the wire brush you can. Then drench the threads with WD40 and let sit for about 15 minutes. Then put on the pipe wrench and give it a good tug. You might want to slide on a pipe to the pipewrench for extra leverage.
If you can get it a little loose, then tighten up brush up again, WD it again, and work it out back and forth a bit at a time.
If that doesn't work, try dynomite.
Old May 16, 2002 | 10:40 PM
banzaitoyota's Avatar
What Subscription?
I would just use the plasma cutter or well an old wrench or stout rod to it and remove it.
Old May 16, 2002 | 11:19 PM
opelbits's Avatar
Having some posting issues here. If this goes thru, I'll post an answer to your problem.
Old May 16, 2002 | 11:42 PM
opelbits's Avatar
I'm trying, really!
I log in.
I am thanked for logging in.
I type a reply.
I am told I am not logged in.
WTF!
Old May 17, 2002 | 12:04 AM
opelbits's Avatar
Once again I try!(sixth time)
Hammer a slightly smaller socket (1/2" drive only) all the way onto the stripped bolt or nut. SAE stuff works well for metric hardware. With a suitable breaker bar on the socket and a good wrench on the other side (brace the wrenck against something solid), loosen the bolt. It should come loose or shear off. You may have to TIGHTEN the bolt to get it to shear if loosening does not work. I have done this many times, but not on anything larger than a 15mm bolt head.
Be creful!
Good luck!
Old May 17, 2002 | 12:08 AM
opelbits's Avatar
Oh, yeah, if you use cheap tools or a ratchet instead of a breaker bar, you may break the bolt, socket, breaker bar, ratchet, and maybe a bone. Think it through before you do it.
Old May 17, 2002 | 11:26 PM
execelon1's Avatar
drill it out, not much noise, or wait till morn and then beat the hell out of it
Old May 18, 2002 | 05:42 AM
HAILERS's Avatar
HAILERS
Its time to invest in a Dremel motor and some cutting disks for it. Cut the head off. All the above work just fine too.
Old May 18, 2002 | 06:30 AM
Poppinrex7's Avatar
he definitely doesnt have a plasma cutter...my plasma cutter sucks anyway, real hard to get a good ground with it....
Old May 18, 2002 | 09:43 AM
Dremel is how I do it... takes some cutting disks to do, but it works great... remove the head, then hammer it out (quietly )
Old May 18, 2002 | 10:08 AM
Aaron Cake's Avatar
Engine, Not Motor
Try a nut-splitter. It goes around the nut and you use a socket wrench to turn a bolt which forces a chisel into the nut. Splits it right in half.
Old May 18, 2002 | 01:05 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
go to sears and get a .....this is going to sound painful...... a nut splitter. when dealing with rusty nuts and bolts there isnat anything better or easier.
Old May 18, 2002 | 01:14 PM
HAILERS's Avatar
HAILERS
Gross ignorance here: would a nut splitter work on a bolt head. I think thats what was described in the lead post?????? Yeah. I need a nut splitter. There's been some nuts I've cut off with the Dremel, which works good, but I question whether a nut splitter would work on a bolt head.?????????
Old May 18, 2002 | 01:16 PM
Felix Wankel's Avatar
Super Newbie
Cats should be held on by nuts, the first post is just interchanging the word nut and bolt probably.
