Need Help with my 88 Fc
After running for a while the idle drops to 2-300rpms and then will die out in neutral or when i push the clutch in. After wards it wont start. I tested it in my school shop and it was running rich then normal then lean and then rich again. I was told it could be the ignition problem or the crankshaft or a fuel promise. Help me out please!
Also it has a flooding problem..
Possible Problems
1) Leaking Fuel Injector
2) Timing Off
3) Thermo-wax pellet not working right, it holds the car at a higher idle untill warm, increase the idle some when it is cold.
4) TPS out
5) Low Compresson (Use Normal compresson tester modded for use with Rotary)
2) Timing Off
4) TPS out
