Anyone know how to remove door panel if door wont open?
Old May 16, 2002 | 08:37 PM
BicuspiD's Avatar
Infamous...Butcher...
Im dying over here, killing my car dukes of hazzarding my fat *** in and out the psgr side. Sunroofs rock!
scuse my language
tks!
-Richard-
Old May 16, 2002 | 09:08 PM
Zoomspeed's Avatar
y won't the door open?
Old May 16, 2002 | 09:11 PM
BicuspiD's Avatar
OK well lets pretend that you, too had this problem..
Do this..
Opposite the outer door handle is a plastic trim on the inside of the car. Pull it off. Go ahead, do it. Don't be scared. Be authorative, Its your car! But dont break it. Probably not cheap.
You will see two 10mm nuts. take em off, and the outer door handle can be "displaced" by pushing the studs in. You will see the two pushrod connectors that control the door latch and locking mechanism. Push down on the forward most one and fully disengage the lock.
The door should open now . Yay! . take this time to spray a little contact cleaner/lubricant on the mechanism, and work it a little bit back and forth and I "dribbled" a little down the pushrod with hope it made it down to the lock.
After tightening and cleaning everything, the latch and lock work MUCH better. Since it takes less than 5 mins ( to do both sides) you might want to do a little preventive maintenance and not go through what I went through today!
peace out
-Richard-
runner83
1st Gen General Discussion
16
Aug 26, 2015 05:16 PM
