What's the plastic hat thing on the end of the injectors.
Old May 16, 2002 | 08:22 PM
P'cola FD's Avatar
Hamado things my way!
I have my car torn apart replacing the wiring harness and some MOP lines. I decided to take out my injectors and put new o-rings on. I ordered new o-rings and insulators(which I thought was what I was looking for), but didn't get the things on the end of the injectors.
What I'm looking for is on the tip of the secondary injectors. It looks like a brown hat. It is made of plastic and has the fuel rail on the bottom of it, a small o-ring on the top side of it, and an injector inside of it.
What is the name of this, and is there anywhere I can get it from that won't take a week? Thanks.
Old May 16, 2002 | 09:28 PM
Brad's Avatar
dear baby jesus...
It's called a pintle cap. You can buy them here... http://www.mazdatrix.com/getprice.as...m=13-MZTX-0002
While you had them out you shoulda sent them to RC engineering to get flow matched and cleaned. It's only $24 per injector and they replace all the o-rings and pintle caps for you. You'd be surprised at how dirty they can be. When I sent my primaries in they flowed at like 505cc and 520cc. They now both flow 552cc.
Old May 16, 2002 | 09:29 PM
P'cola FD's Avatar
Thanks a lot man.
Old May 17, 2002 | 12:58 AM
whats the purpose of the pintle cap? when i replaced my o-rings, one of the caps had a small crack down the side.
Old May 17, 2002 | 09:19 AM
FastX7's Avatar
When I put in my new injectors... one cap was cracked, the other was totally off the injector and one other was what appeared to be burned.
Old May 17, 2002 | 01:13 PM
Brad's Avatar
dear baby jesus...
Found this on some website...
"Fuel injectors meter the amount of fuel delivered to the inlet air. When the injector is off, the spring keeps the needle against the seat, preventing fuel flow. Energizing a solenoid winding pulls the needle back against spring pressure (it moves only about 0.006 in.), allowing fuel to flow through the annular passage around the needle and out through the injector tip. The needle tip, the pintle, is designed to break up the liquid fuel into a fine spray to promote rapid formation of vapor and enhance the mixing of fuel and air."
So...probably not a good idea to have a broken or burned pintle cap. As far as I know, you can only get the pintle caps for the secondary injectors from Mazdatrix. You can't get the primaries from them. You'd have to try RC Engineering for the primary ones.
Old May 17, 2002 | 06:01 PM
thanks
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
