tranny noise dianosis...anyone?
Old Nov 30, 2008 | 02:41 PM
mortiky's Avatar
AL tranny noise dianosis...anyone?
ok so I'm starting to notice more noise from my trans than usual, Oil is good, switched it out with a synthetic blend when i swapped motors. i'm thinking it is just the old '79s transmission telling me it isn't going to hold up with the power i'm putting in it now. you can hear a small noise when the clutch is engaged (pedal not depressed)and your in neutral. but really i'm noticing a pronounced whine whilst deceleratrting(engine braking) in 1st, 2nd, & 3rd...and seems to be more noticable as you go up the gears, it seems likely this could just be because its not spining as fast, makes it seem like it would be a counter shaft bearing maybe? anyone have any ideas. i'm gonna replace it either way, just was curious on any other opinons on it.
Jetlag
Sep 29, 2015 06:52 AM
