Power FC a few charts for fun! almost 17psi on stock seq twins
Old Nov 30, 2008 | 04:14 AM
neit_jnf's Avatar
relevant mods:
INHALE:
M2 airbox, ASP large SMIC, upgraded y-pipe
EXHALE:
SMB 4inch downpipe, SMB 3.5inch metal cat resonated midpipe, RB 3inch Dual Catback
BURN:
550/1300 injectors, HKS Twinpower, BR10EIX plugs all around
BRAIN:
PFC - controlling boost as well (settings 1.3/100 1.3/80)
Using a v7.07 base map with only injector size and timing map changes, fuel is not tuned
Run done in 3rd gear, didn't take to redline because ran out of road.
boost 15-10-16.5
max duty cycle 77%
comments?
Attached Thumbnails a few charts for fun!  almost 17psi on stock seq twins-primary.jpg   a few charts for fun!  almost 17psi on stock seq twins-transition.jpg   a few charts for fun!  almost 17psi on stock seq twins-secondary.jpg   a few charts for fun!  almost 17psi on stock seq twins-max-inj-duty.jpg
Old Nov 30, 2008 | 10:29 AM
thewird's Avatar
Bets on how long the turbo's will last?
Also, your not making more power by running the turbo so high, its out of its efficiency range. Your just stressing the turbo's and generating a ton of heat for no reason.
thewird
Old Nov 30, 2008 | 10:52 AM
neit_jnf's Avatar
i dont run them that high all the time, i usually daily drive at 9 psi. i've only done about 5 or 6 3rd gear pulls at 17psi
ait's remain in check, no higher that at low boost
i plan to dyno it after i trim the fuel a bit and see what it gets. tom94rx7 runs them at 19-20 psi and has consistent very low 11s quarter mile times
Old Nov 30, 2008 | 02:00 PM
moconnor's Avatar
You are obscuring the Y axis scale.
That is a brutal looking transition.
Old Nov 30, 2008 | 02:14 PM
neit_jnf's Avatar
i didnt set the y scale correctly i think, it goes 0 to 250 but it doesnt correlate to anything thats why i opened the watches and started looking at the values.
Old Nov 30, 2008 | 11:08 PM
arghx's Avatar
rotorhead
I can't seem to get more than 10psi during transition either...
Old Nov 30, 2008 | 11:43 PM
moconnor's Avatar
Me neither. I'm running 14-9-14 psi at the moment with dual Hallman MBCs and have perfect, repeatable fine-grained control of both primary and secondary boost but my pre-control boost will not build up beyond 8-9 psi.
My current theory (and I've had lots) is that the pre-control wastegate will simply not flow enough when it is venting primary boost to spool the secondary beyond 8-9 psi. I've though about porting the pre-control wastegate but that may simply reduce primary boost.
I hope I'm wrong. I've seen reports of 14-12-14 psi boost patterns but I'd like to see the logs - I don't trust boost gauge reports.
C. Ludwig
Jan 30, 2019 06:31 AM
The1Sun
Mar 18, 2018 11:08 PM
msilvia
28
Apr 14, 2016 12:58 PM
rxmiles
Aug 24, 2015 02:07 PM
