Brake lights not working
Old Nov 28, 2008 | 12:35 PM
JoeyMazda's Avatar
"81 RX-7
PA Brake lights not working
I have an 81 rx-7. Taillights work but when I step on the brake they don't come on. It's not the bolts or the brake switch,both are good. Any suggestions? Thanks in advance.
Old Nov 28, 2008 | 01:58 PM
Aaron Cake's Avatar
Engine, Not Motor
Check the fuse.
Do you have 12V at the brake switch to ground?
Old Nov 28, 2008 | 06:45 PM
JoeyMazda's Avatar
"81 RX-7
Not the fuse either,I checked it
Old Nov 28, 2008 | 11:13 PM
misterstyx69's Avatar
Retired Moderator, RIP
check the harness for the lights at the back of the car,behind the Rear carpetting.You could have a Bad harness.Did you check the bulbs or the Sockets?
Old Nov 28, 2008 | 11:28 PM
JoeyMazda's Avatar
"81 RX-7
Thanks for the suggestions but I checked it already and its good. I also checked the bolts, the fuse, brake switch,the groung is good. I'm still troubleshooting through everything. Hope to find it soon so I don't get stopped.
Old Nov 29, 2008 | 10:38 AM
Aaron Cake's Avatar
Engine, Not Motor
OK. The '81 pulls power for the taillights directly from the battery via the white/red wire if my schematic is correct. Thus if you have no 12V at the 15A fuse or at the switch, then there is a break in the wire. The horn is on the same circuit. Does it work?
Old Nov 29, 2008 | 12:39 PM
JoeyMazda's Avatar
"81 RX-7
My horn is working. I took care of the problem temporarily by running an extra wire from the brake switch to the main brake taillight wire. I still have to get to the bottom of this because now the brake light on the dash is on.
Old Nov 29, 2008 | 02:14 PM
norfy's Avatar
gotta be a broken wire then
Old Nov 29, 2008 | 09:51 PM
JoeyMazda's Avatar
"81 RX-7
After troubleshooting for a few hours I finally figured it out. It was the brake light switch relay.
fastsaab
Aug 19, 2015 11:42 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
