Megasquirt Secondary Injector Problem....
Old Nov 20, 2008 | 06:36 PM
Smokems's Avatar
I love my 13bT
Ok well my tuning is going along...but ive run into another wall...Im trying to break the motor in properly and its time to start reving it to 4k a lil....but the second i pass the point when the secondary injectors come on....all i get is a massive lean out... and thats it...It wont let me go past 3400-3500.... please advise....ive tried adding fuel..still the same problem. Well any advice/help would be great
Thanks again.
Saheed
Old Nov 20, 2008 | 10:24 PM
13bdarren's Avatar
what injector are you using and post you msq so we can have a look of your settings.
Old Nov 20, 2008 | 10:30 PM
toplessFC3Sman's Avatar
What version of MS are you running?
If MS1-e, make sure that you have the correct scaling factor for staging, and that the MS is giving an output on the 2nd injector channel.
If MS2-e, use the output test mode to test the output for injector 2 while everythings in the car and hooked up (BRIEFLY, so you dont flood it, and WITH THE CAR NOT RUNNING) and see if you can hear them making any noise.
Old Nov 21, 2008 | 05:39 AM
Smokems's Avatar
I love my 13bT
Here you guys go...My current Map Im Using..... Please any info would be greatly helpful. Thanks
File Type: zip
Old Nov 21, 2008 | 05:52 PM
13bdarren's Avatar
what size injectors are you using and do you have a datalog
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
ZacMan
Sep 19, 2015 09:20 PM
